1998 JEEP GRAND CHEROKEE ZJ 4.0L 4WD
  • DWILLIAMS5106
  • DWILLIAMS5106's Avatar Topic Author
3 days 7 hours ago - 3 days 1 hour ago #93365 by DWILLIAMS5106
1998 JEEP GRAND CHEROKEE ZJ 4.0L 4WD was created by DWILLIAMS5106
HELLO,
22 NOV 2026 | 1512
I HAVE 2 FLASHMASTER PCMS. ONE I HAVE TO SHIP BACK EVENTUALLY. I SAW THE VIDEO ON THE 96 JEEP, I SAW THE MAP SENSOR VIDEO THAT WAS COMMENTED ON THAT VIDEO & THEN THE OTHER VIDEO I JUST WATCHED ON A 98 JGC FOR TPS SIGNAL SHORTED TO 12V VIDEO. I REALLY THOUGH THAT ONE WAS GOING TO HELP ME YET IT ENDED UP BEING A BENT PIN IN THE PCM & THEN THE JEEP STARTED UP.
MY CURRENT SITUATION. NO CRANK, NO START. NEW CRANKSHAFT POSITION SENSOR, NEW IAC, NEW TPS, NEW IGNITION COIL & MOUNTING BOLTS & GROUNDS CLEANED TO SHINY BARE METAL. NEW DISTRIBUTOR CAP & NEW ROTOR. NEW RELAYS & FUSES. WHEN I TURN THE KEY TO RUN, THE FUEL PUMP PRIMES CONSISTENTLY, NO GAUGES, NO COMM TO SCANNER, CHECK ENGINE LIGHT DOESN'T STAY ON ALL THE TIME, SOMETIMES IT DOES DEPENDING ON WHAT CONNECTOR IS WIGGLED [NOT REALLY SURE] AND THE ASD & FUEL PUMP RELAYS CLICK RAPIDLY. I HAVEN'T SEEN ANY VIDEOS ON THAT.
I HAVE USED THE TEST LIGHT TO CHECK FUSES IN THE PDC ALL SHOW 12V ON BOTH PINS. MINI FUSE 18 ONLY SHOWS 12V WITH THE KEY SET TO RUN. IT RAN FOR 2 DAYS FOR 80 MILES TOTAL A FEW WEEKS AGO WITH THE FIRST FLASHMASTERS PCM. BEFORE THAT I HAD A FLAGSHIP ONE PCM INSTALLED & IT WORKED FINE UNTIL I HAD TO GET A NEW BATTERY. FRESH NEW BATTER INSTALLED CAUSE SO MANY ISSUES FOR WHATEVER REASON WHICH HAD ME CHANGE THE CRANKSHAFT POSITION SENSOR, IGNITION COIL, NEW BATTERY TERMINALS, THROTTLE POSITION SENSOR, THROTTLE BODY GASKET, CLEANED THROTTLE BODY, IAC SENSOR, COOLANT TEMP SENSOR & THROTTLE POSITION SENSOR.
PLEASE HELP ME. IF I NEED TO TAKE A VIDEO TO SEND IT TO SOMEONE I CAN DO THAT TOO.
THANK YOU IN ADVANCE.
2051 - I COULDN'T BACK PROBE THE BLACK C1 PCM CONNECTOR WITH THE T PINS SO I CONNECTED BY TEST LIGHT TO THE POSITIVE BATTERY TERMINAL & TESTED THE FRONT & A2 LIT UP GREEN WITH 12 VOLTS YET THE GROUNDS A32 & A31 DID NOT LIGHT UP OR SHOW ANY VOLTS. I UNDID THE WHITE LOOM FROM THE BOTTOM OF THE C1 PCM CONNECTOR THAT ROUTED ALL THE WAY TO THE IGNITION COIL GROUNDS & THE WIRES [A32 & A31] BLACK/TAN. TEST LIGHT AT THE NECK OF THE WIRE TERMINAL CONNECTIONS LIT UP GREEN & 12 VOLTS AS WELL. I DON'T KNOW WHAT IS GOING ON.
Last edit: 3 days 1 hour ago by DWILLIAMS5106. Reason: ADDITIONAL TESTING
2 days 17 hours ago - 2 days 16 hours ago #93366 by Noah
Replied by Noah on topic 1998 JEEP GRAND CHEROKEE ZJ 4.0L 4WD
There's certainly a lot to digest here, but not much context.
I realize your are in the thick of it, but understand that no body else knows what a2, a32 or mini fuse 13 are. Please explain what you are testing and why as well as the results as clearly as possible for anyone who may wish to help you.
Clicking relays is almost always a low voltage or poor ground issue. If you have no communication to the PCM, I recommend checking all the powers and grounds at the PCM and checking for a possibly shorted 5v reference circuit.
Can you expand on this? Again, a lot of stuff changed but no real explanation what lead up to these repairs.
Is that "Fresh new battery CAUSED so many issues" or "Fresh new battery BECAUSE so many issues".
It reads like the jeep was running, then it needed a battery, and never ran again once you changed the battery. Is that correct? Did it perhaps accidentally get jump started backwards or have the battery installed reverse polarity for a moment?
Last edit: 2 days 16 hours ago by Noah.
  • DWILLIAMS5106
1 day 11 hours ago #93367 by DWILLIAMS5106
Replied by DWILLIAMS5106 on topic 1998 JEEP GRAND CHEROKEE ZJ 4.0L 4WD
I did give context in the paragraph I mentioned it is the pin connections on the C1 Black PCM Connector. I was pretty thorough in my post.
I've already done the 5v reference check and nothing checks out as Paul videos were showing. A32 & A31 on the C1 Black connector as said in the jeep video are the grounds and I undid the wire loom and followed it all the way to the ignition coil & there are no breaks in the wire & no frays no copper wire showing at all. Yes when you turn the key to run the ASD clicks. I have done the 5v testing & have done the unplug sensor one by one & testing from the front of the mpa sensor or the throttle position sensor the reading on each contact is around 8.6 volts. Accoring to Paul's videos that means it's pulling battery voltage somewhere.
I have more back prob tools delivered from Amazon & a wire disconnect tools to check the wires when I pull them out of the PCM C1 Black connector housing.
Yes that is correct. The Jeep was running well apart from the heat soak issues with driving on the highway then parking at the store for about 20 mins then getting back in and having a hard time starting it yet eventually getting it to start & run to drive where I need to go. Battery died, got a new one, then had to replace all those parts due to the codes coming up on the scanner & now I'm at this point with no running Jeep, no communication to the scanner & looking at endless videos & forums trying to find a fix yet nothing matches totally what I'm going through so the jeep sits in the parking lot.
1 day 9 hours ago - 1 day 9 hours ago #93368 by Noah
Thanks for the update.
Have you gotten a proper wire diagram for this vehicle? It will be essential to troubleshoot this issue, even if you just buy a temporary service info sub or Haynes manual.
What I meant by context, is that you are the only one that knows what you are checking here. Because you didn't provide a diagram, a video link or even say "I checked for voltage at such and such pin of such and such connector, and checked ground at this pin of this connector", it's hard to know what the results of your tests are supposed to be.
From your last post, it sounds like you are using some kind of logic probe or power probe for your circuit checks. Ideally you will want to load test the power and ground circuits with an incandescent test light, or bulb that can pull an amp or two.
Rapid clicking relays strongly favors a voltage drop on a power or ground circuit.
So you are saying there is more than 8v on the 5v reference circuit? That can be a bad PCM ground or a bad PCM. Again, you will need to reference the appropriate diagram for this vehicle and properly load all the powers and grounds to check for voltage drop.
So something changed, because you clearly had communication to have pulled codes for all these parts. So changed the battery, read the codes, changed all these parts and now it's a no communication no crank scenario? Just trying to get the timeline straight from when it went from running to not and what happened in between.
With that said, I think you are dealing with 2 issues regarding the no communication and the no crank. The PCM is not involved in the starter circuit on this generation Grand Cherokee. I would probably investigate the cranking issue first. You mind find a missing power or ground that is also impacting the PCM.
Last edit: 1 day 9 hours ago by Noah.
  • DWILLIAMS5106
15 hours 23 minutes ago #93369 by DWILLIAMS5106
No i do not have my own wiring diagram. I followed what Paul did in his video.
I wish i had the simple fix of a frayed o2 sensor wire like he had in the video. None of my wires are frayed. used a multimeter like he did. I used a test light with a voltage display to test the fuses in the power distribution center.
14 hours 18 minutes ago - 14 hours 14 minutes ago #93370 by Noah
Find attached starting system diagram as well as complete engine control diagram.
Early Christmas gift. 😉
Print them out soon or download them, I don't want to leave them up here for the public at large.
Last edit: 14 hours 14 minutes ago by Noah.
