2018 Ford F-150 5.0(misfire on 5 and 6 after engine replacement)
1 week 2 days ago - 1 week 2 days ago #93354 by Joya
Hey guys i'm stumbling on this weird one. so i replaced the engine because it had a cracked block and it wouldn't start. so after we got approval to replace engine. engine assembly was a complete assembly reman. from dealership came with valve cover, spark plugs, and oil already in it, i went ahead and installed it, everything went smooth until it started............. it has a dead miss when RPMS stabilize. so i did the first thing that came to mind swap coils, misfire was not following, it got to the point were port injectors and direct injector were swapped and still misfire on 5 i performed a noid test to coil and injector, and bulb come on as a pulse. i removed the intake again and performed wire harness check direct injector internal resistance was 1.8 compared it with injector from cylinder 1 and it was 1.9 which is good. performed resistance check from connector c1279 pin 11 to connector c186 to pin 1 and connector c1279 pin10 with c186 with pin 2 both were at 0.1 ohms. i did the same resistance check from connector c1279 pins 11/10 to pcm connector c1381e pins 3 & 24 and resistance was at 0.4. performed a load test from connector c1279 to pcm connector, and load test passed with a bright light. we also removed valve cover and we were not able to see any damage. i guess at this point what i haven't done is check valve clearance, but i'm at a lost now and would like some help. i also performed a in cylinder test, which i will attach here for you guys help me analyze it
Last edit: 1 week 2 days ago by Joya.
1 week 1 day ago #93358 by Chad
Compare that in-cylinder waveform with an in-cylinder waveform from the other bank.
Also, post a relative compression waveform, with sync.
