2019 VW Tiguan Se with code p009000
- Motorhead
- Thank you received: 5
2 weeks 1 day ago #93340
by Motorhead
2019 VW Tiguan Se with code p009000 was created by Motorhead
I have a 2019 VW Tiguan SE with code P009000, and suspect a harness issue. My question is can I Unplug the connector at the fuel pressure regulator/high pressure fuel pump, and connect a test light to the harness to check if the circuit for the harness is ok?
- Thank you received: 745
2 weeks 5 hours ago #93344
Replied by Chad on topic 2019 VW Tiguan Se with code p009000
Yes, that would be a good test to determine wire/circuit integrity. Be sure to use an incandescent test light. Not, an LED test light.
What other tool do you have? If you have a volt meter, you could you it to measure voltage drop, too.
- Motorhead
2 weeks 2 hours ago #93345
by Motorhead
Replied by Motorhead on topic 2019 VW Tiguan Se with code p009000
Thank you. Yes, I have a voltmeter, incandescent test light, also I have a bidirectional scan tool.
- Motorhead
2 weeks 2 hours ago #93346
by Motorhead
