1991 Escort Right Turn Stall
- Cordes
I'm not sure if it makes a difference, but it's a California emissions car.
What I know:
When the car stalls it won't restart for a couple minutes or at most a couple of hours. It's almost always about 10 min.
When it won't start, it'll generate spark, but I'm 99% sure the ECU won't fire the injectors. The one time I was able to setup everything to test I was able to see there was spark, but smelled nothing fuel wise nor did I see any fuel on the plugs. The last time my wife tried to fire it up while I was looking at the plugs the smell of fuel hit hard, I put the injectors back in and it fired up like normal.
Codes: The only stored code was 95 which is described as: (o) Fuel pump: open, bad ground or always on – Power / Fuel Pump Circuits; (R) AIR not Diverting (AIRD) – Air Injection; (M) Possible bad fuel pump ground or open between fuel pump and pin 8 at PCM (Fuel Pump Monitor signal) – Power / Fuel Pump Circuits That appears to have cleared itself and now I just get a code 11 which is that the self test is OK.
Things I've replaced with no difference in the problem(only because they're crazy cheap):
ECU
Inertia switch
To help get an idea of the condition of the car and wiring, it's a socal car with 62K on it and everything looks pristine.
I've checked the following wires with my Load Pro and they all tested good:
FP relay power wire to pump
FP ground
FP relay to pin 19 at EEC
Connector C100 cam sensor wires to cam sensor terminals
I've also checked the FP relay and the inertia switch. Both tested good. I replaced the inertia switch, but the problem is still there.
The cam sensor seems to be weeping just a tiny amount of oil out through the pins to the terminals on the harness. I should probably replace it, but that requires removing the intake manifold. Grrrrrr.
There was apparently at TSB for stalls if the fuel sender shorts to ground. Mine didn't have the fix done, but I can't make much of what they really did: Harness Modification TSB
I do have an oscilloscope which can take pictures and capture data, but I'm not good with it at all. I've attached some nice screenshots I've taken of the crank signal with a couple other things thrown in. The hardest part about this is that I'm not sure exactly how the car uses the different signals to trigger different events such as turning on injectors.
I've seen some indications that a short in the O2 sensor wiring could somehow pull the FP circuit wiring signal to ground and cause an issue. I looked at the wiring for the O2 sensor today while poking around. It looked good and I didn't do anything other than a visual inspection of it.
Any, and I do many any suggestions are highly welcome.
- Thank you received: 1142
Looks like the harness upgrade is just an extension with some fuses. Easy enough to pop the back seat and see if there's chaffing of wires.
Really, you need to identify what is being lost to know how to proceed with diagnosis.
in my experience, a fuel pump dropping off won't just kill the engine clean. It will run on the fuel in the lines, struggle and die. So if its a sharp, quick stall I wouldn't immediately suspect the pump.
However, it would be easy enough to put a fuel pressure gauge on the rail to verify during or after the stall.
Not sure what those scope captures are you have there, but since you have a scope I would be watching injector control and coil control at minimum, and if you have more channels probably cam and crank sensor signals while driving. Or, if it remains a no start long enough after the stall you can check those things while it's not starting.
- Cordes
I did conduct a test tonight, and it'll keep running with no discernible change if I unplug the cam sensor, so I highly doubt that's part of the issue.
I'm fairly certain that it's not the pump, as I've driven around with a fuel pressure gauge taped to the windshield while doing turns in the outlet mall parking lot and that was rock solid.
I think I need to investigate the crank wiring more, as that's one of the few things which can cause the car to just out and out die I think.
- Thank you received: 745
I just want to comment about your waveforms. You have a massive amount of AC ripple in your waveforms. Your cam signal should be a clean square-wave. Check to make sure that your scope has a good ground connection with the negative battery post. If your scope ground is good, you may want to check for AC Ripple in the charging system.
Your Crank signal looks like a good clean AC sine-wave, as it should. I can't tell what the amplitude is, though.
You need to have your scope hooked up and recording, while you are driving around. Be ready to hit the pause/stop button and save the file as soon as the vehicle stalls.That's the whole problem with this thing. I can't get it to die for long enough to actually hook up a scope and see what's working and what's not.
It can be a bit of a PITA to set up, but you gotta do what you gotta do.
- Cordes
I'll make sure to keep this thread updated. Being that the problem manifests itself so infrequently, I'm not sure I'll be able to just drive about with my 4 channel scope hooked up, but I'll see what I can do.
I'll definitely test the alternator for AC ripple soon. I've had a bad cutout which was a failing alternator and that was no fun. It finally stopped cutting out when the alternator died. That one stumped the whole gang at a Shelby Dodge event though a couple guys suggested it be checked if only we had a scope...
- Cordes
Here is the result of my AC ripple test once we got home. I think the waveform looks pretty good. I'm still new at all of this, so if I'm off base, please let me know.
I did get a noid light on there when it stalled. It seemed like it was functioning well, but the light seemed a little dim to me? It was bright enough outside at the time, and it's the first time I've used one, so I'm not exactly sure.
I also jacked up the right side of the car some and shook it from side to side to beat the band. Nothing doing there...
What should I test next?
Managed to get a noid light on what exactly?
Were you able to check for spark or fuel pressure while the car was stalled?
Even without a gauge you could press the schrader valve in the test port with a pocket screwdriver to verify at least the presence of fuel or evidence of aeration, or did you listen for the fuel pump while cycling the key or cranking the engine, especially with two of you there for such a long period of time?
Do you keep a can of brake cleaner or starting fluid or propane plumbers torch in the car that you might have used to try and get it to fire on alternative fuel after it stalled?
Does it just sharply stall and die or does it sputter out?
When it does die and you cycle the key, does the check engine light illuminate and stay on? That's a good indication the the PCM is alive. If so, does the engine light go off while cranking? That's a good indication that the PCM is seeing the crank sensor signal.
- Cordes
The bottom waveform looks like a normal ac ripple pattern to me. What is the top waveform?
Thank you very much for the reply.
The top waveform is a built in reference waveform in the scope. That's not anything I did. I'm glad that looks normal and my thinking is most likely correct on that.
I put a noid light on the #1 injector connector and it did flash while my son was turning the key to crank the engine over.
I wasn't able to check for spark or fuel pressure yesterday, but in the past it has had at least some fuel pressure and spark.
The pump definitely primes and sounds normal.
I'll be putting some starting fluid in the car tonight. I actually looked at the intake to see that there is a nice nipple on there near the TB which I could remove a vacuum cap from tho squirt it right in there.
It can sometimes sputter or die right on the spot. I've had it do both with equal zest. Yesterday it acted like it wanted to start a few times before it died out.
The CEL comes on and then goes out while cranking as one would expect.
With yesterday's testing of the noid light, and the good AC ripple test, I'm thinking that there may be something floating around near the sock for the pump that's getting in the way on hard right turns. It then moves away over time as gravity again takes hold. All of my electrical testing indicates that the wiring and connectors are in tip top shape. One of the few things I've not tested is the actual diode for flyback suppression at the pump. I'm getting desperate and the weather will be super nice this upcoming weekend. My plan is to run the fuel down driving the car back and forth to work this week and to do a visual inspection of the entire tank. I could have missed something big when I replaced the FP recently.
Any other ideas will be put on the list for sure. I'm just a back yard mechanic, but given that I've only paid for someone to work on my vehicles 2-3 times in my entire life I'm fairly well outfitted for whatever you guys direct me to do. I greatly appreciate the support you folks have given already.
The problem turned out to be very low engine oil. The oil pickup was on the right side. Turning right would send all of the oil to the left, causing loss of oil pressure. This vehicle, however, had no problem restarting.
- Cordes
Out of curiosity, have you checked the oil level? Years ago, I had a vehicle that would stall, only during right turns. I can't recall what Make and Model.
We generally check the oil at every fill up, so the level is good. That's an interesting thought, and I'll keep that in the back of my mind for the future. I don't think these have a low oil pressure engine cutoff.
- Cordes
I pulled a bunch of junk out of the tank that I missed when I originally replaced the pump. It looks like whoever was in there before me didn't bother to clean anything out at all. The car sitting for about 20 years looks to have caused the sock to disintegrate and a lot of other junk was in there too.
I pulled it all out and then put the pump back in. Of course Rockauto had to send the wrong pump sock so I reused the old one. It's not ideal, but it ran well enough when removed that I'll use it until the new one gets in.
Of course now it doesn't want to make a lot of fuel pressure. It's also somewhat hit and miss in regard to making it in the first place. I'm at a loss in regard to what's actually causing it, but it does seem to die just like on a right hand turn.
When I sprayed starting fluid in there it would fire right up reliably.
I'm calling this one a fuel problem and going to chase that now. Good times...
