1999 Silverado 1500 5.3 Rich on both banks
  • Lui1522
  • Lui1522's Avatar Topic Author
3 weeks 2 days ago #93321 by Lui1522
99 Silverado 5.3 LM7 Rich on both banks
I feel like I have eliminated everything and ran out of ideas
FT at idle sit around -10 total
FT at 2500 RPM around -25 total
-ECT goes from 60°to 210° as the truck warms up and completes a heat cycle no issues there
-MAF brand new Delphi around 5.5
-Both 02 sensors switch from 200 to 900 MV and both react to a rich and lean condition
-Fuel pressure KOEO 55 PSI
-Fuel pressure at idle 48 PSI
-Fuel pressure at 2500 RPM seems to be around 48
holds 48 PSI after 10 minutes
-Injector leak down 5 PSI drop across all 8
-I have also removed the purge valve and vacuum tested it, it was sealed unplugged it while the truck was running and it sealed,  removed the purge line as well and still rich condition
- I checked the FPR for a torn diaphragm and no fuel was coming out of it
- Removed the PCV hose
The truck also runs well and doesn’t seem to have any restrictions on the exhaust it picks up speed just fine no actual drivability issues
3 weeks 5 hours ago - 3 weeks 5 hours ago #93323 by Chad
At this point, I don't think "doesn't seem to" is good enough. I think that you should check exhaust back pressure with a gauge.
I would recommend doing a volumetric efficiency test, too. A google search should find a variety of calculators.
Something else to look at would be Cam Timing pids. What is Actual vs. Desired?
Last edit: 3 weeks 5 hours ago by Chad.
2 weeks 3 days ago - 2 weeks 3 days ago #93328 by Noah
Setting rich trouble codes or are you just noticing a trend with the fuel trims?
I agree with Chad, we can't fix cars based on how things seem. Definitely need quantifiable values for exhaust back pressure and VE.
Does the map sensor accurately reflect your barometic pressure key on engine off as well as vacuum with the engine running?
Is there a data PID for fuel ethanol content?
Any recent work leading up to this, (like O2 sensors, "tune up", fuel injectors, cold air intake etc)?
Last edit: 2 weeks 3 days ago by Noah.
  • Lui1522
2 weeks 1 day ago #93341 by Lui1522
Replied by Lui1522 on topic 1999 Silverado 1500 5.3 Rich on both banks
Apologies for such a late response, i don’t have any history on this truck I bought it for 600$ off marketplace.
I haven’t done any work to it either than a MAF and 1 upstream 02 sensor.
I also went ahead and did a back pressure test, 1.5 psi at 2500 rpm, close to nothing at idle and Volumetric efficiency is 90% 240.96 gm/s at 5083 rpm. It is setting rich codes and I can also see it on the fuel trims.
  • Lui1522
2 weeks 1 day ago #93342 by Lui1522
I went ahead and did both test, id say the truck passed both, also this is a 99 so no vvt
1 week 5 days ago - 1 week 5 days ago #93347 by Noah
That's certainly interesting. Did you compare the baro and koeo map pids to your actual local baro?
Have you checked for a pid that indicates flex fuel alcohol content?
5psi drop from the injectors during the automated test sounds less than normal, but one.would think that would result in positive fuel trims.
How does the fuel look? I would take a sample just on principle and let it settle in a clean glass container.
I know you disconnected the PCV, but does the oil smell of gas or appear over full?
Did you replace the MAF for this condition, or did this come up after the MAF was changed?
Does this truck still have the OEM air filter and intake? No hot rod cold air intake hopefully...
Last edit: 1 week 5 days ago by Noah.
  • Lui1522
1 week 4 days ago - 1 week 4 days ago #93348 by Lui1522
Baro and map show 30 koeo which is 29.8 here so pretty accurate, there is no pid for flex fuel or any functions for fuel composition, I changed the Maf for this condition after running out of ideas, my oil smells like oil and is at a correct level, the intake system is stock
Last edit: 1 week 4 days ago by Lui1522.
1 week 2 days ago #93353 by Noah
That's very interesting to say the least. There are only so many reasons for a fuel injected engine to run rich at all operating conditions.
If you are positive that:
Fuel is good quality
Oil is not diluted
Baro is accurate
Map is accurate
Engine vacuum is good
O2s are good and functioning
MAF is of good quality and in original position
Fuel pressure is not excessive
Fuel pressure regulator is not feeding fuel into the intake manifold
Then there is virtually nothing left to blame than the injectors themselves. Considering the age and unknown history of the truck, a previous owner could have installed an engine with injectors too large for the application, or maybe even installed cheap injectors to fix an issue or larger injectors to hop it up.
