Loses communication with ABS
  • mjpatitucci
  • mjpatitucci's Avatar Topic Author
2 months 3 weeks ago #93127 by mjpatitucci
Loses communication with ABS was created by mjpatitucci
Good day fellow Technicians,
I am troubleshooting a 2015 Honda Pilot, 101K miles, that looses ABS signal when driving vehicle above 33.84 mph according to my XTool D8BT scanner. At first I suspected the scanner until I checked other systems which are communicating fine. I did another total scan of the vehicle once it was sitting in the driveway. Sure enough… no error codes. I have a subscription to Alldata for the vehicle and will be doing a lot of reading. Has anyone else have a similar experience, loosing communication with a module at a certain speed? Thanks in advance for your input.
Mike
2 months 3 weeks ago #93128 by Chad
Replied by Chad on topic Loses communication with ABS
What, exactly, are you trouble-shooting? Are you getting ABS warning lights?
The fact that you have no codes makes me believe that this is a tool limitation, rather than an actual communication issue.
The following user(s) said Thank You: mjpatitucci
2 months 3 weeks ago #93130 by Noah
Replied by Noah on topic Loses communication with ABS
I agree with Chad. In the past it was not uncommon for Asian imports to drop communication above a certain speed. At least with Snap On and OEM scan tools, there would be a warning on the tool that it would cease to communicate with abs while driving. Unless there's a tangible symptom you are trying to diagnose with the abs, I wouldnt read too much into it.
  • mjpatitucci
1 month 3 hours ago #93298 by mjpatitucci
Replied by mjpatitucci on topic Loses communication with ABS
Thanks Chad, sorry for the delay. I’ve been dealing with another issue with a different vehicle. I’ll be asking the group shortly. I did watch a YouTube video explaining why Honda’s have a communication cutoff when vehicle travels faster than 30 miles an hour.
  • mjpatitucci
1 month 3 hours ago #93299 by mjpatitucci
Thanks Noah, I can not remember the YouTube video I watched that explained some Honda’s cut communication with communication port above 30 miles per hour.
