Suzuki equator Throttle plate not opening with Accelerator pedal
  • Columbus450
  • Columbus450's Avatar Topic Author
7 years 9 months ago #26303 by Columbus450
P2100 tps relay no signal
Snap on modis shows throttle relay is off Cannot locate a relay For it? I believe this is my problem
Vehicle starts and runs only idles Gas pedal does not respond when pressed
Accelerator pedal is working tested opening up on scanner I can see voltage changes
Throttle Body position sensor under hood
6 wire connector
No movement from throttle plate
Ground is good
Reference is good
Signal wire There is a signal when I open The plate. By hand No Glitches no dropouts
Question is wires 5 and 6 on my connector failed The integrity test 0 voltage or anything coming out of those 2 wires when I press the accelerator pedal
According to my understanding the accelerator pedal sends the signal to the ecm then the ECM sends the signal to the TPS 5 and 6 wires
The diagram on BBB does not show tps relay I'm at a lost please help
Sent from my SM-N960U using Tapatalk
  • Columbus450
7 years 9 months ago #26306 by Columbus450
Anybody ??
7 years 9 months ago #26307 by Valessilo
Throttle Control motor relay is fed from fuse 52 20A
7 years 9 months ago #26308 by Chad
There is a Throttle Control Motor Relay in the IPDM.
7 years 9 months ago #26309 by Chad
  • Columbus450
7 years 9 months ago #26314 by Columbus450
I did read that too on the diagram but I cannot find it anywhere the IPDM only goes up to number 24?? Wth !?
  • Columbus450
7 years 9 months ago #26315 by Columbus450
That is the thing I cannot find fuse 52 the IDP M only goes up to 24 fuses??
Also I wish I could see the diagram clearer it's pretty blurry
  • Columbus450
7 years 9 months ago #26316 by Columbus450
Its shows This fuse Box as my idpM but this looks nothing like mine Unless these relays were built internally
  • Columbus450
7 years 9 months ago #26317 by Columbus450
Ipdm On the left is from a Nissan exterior the one on the right is from my Suzuki equator this is the 1 the vehicle came with to my shop and was running before the ecm Went bad which I just changed
The weird part is Diagrams for 2010 Suzuki equator shows the Nissan ex IPDM on the left
Which maybe leaves me to believe the wrong one was put in from the beginning not sure it was running fine before
  • Columbus450
7 years 9 months ago #26332 by Columbus450
The idpm does not have a #52 fuse, After more research it looks like I have the updated version idpm the older version had more relays and fuses , I am more so Betting that the problem is in this idpm in the circuit board
I Wonder why a diagram for a 2010 Suzuki equator Doesn't show my Box
