2015 jeep grand Cherokee 3.0 turbo diesel has could p0299 after turbo replacement
  • Thrashnasty13
  • Thrashnasty13's Avatar Topic Author
5 months 2 weeks ago #92924 by Thrashnasty13
This jeep came in with a lean code, found turbo with blown seals causing oil consumption, also intake manifold had lots of soot. Replaced turbo, cleaned EGR and intake manifold. Once complete jeep started to set p0299 for low boost pressure. Watched live data, car is desiring 75inhg, which converts to 36.8 psi, MAP sensor is only reading 30 psi under load. I have used scan tool and a hand pump to apply pressure to map sensor, found it was reading accurately up to 20 psi of hand pump. Barometric pressure is reading accurate to my location within 5 percent. I have checked for exhaust leaks at turbo using a smoke machine and used the smoke machine on boost piping and intake piping, found no leaks. Reused smoke machine on crankcase and found no leaks. Used pressure adapters to apply 30 psi to charge piping and intercooler, it held pressure for 5 mins. I have verified that the VGT actuator follows command and during drive its matching desired. Swirl actuators are also matching desired. Looking for insight, what am i missing?
  • Thrashnasty13
5 months 1 week ago #92929 by Thrashnasty13
We found that the new turbo had a faulty VGT actuator, even though i looked at VGT actual and desired position and it showed they matched. The actuator wasn't travelling enough to make the desired boost. We went on a whim and replaced with the factory actuator and it fixed the low boost issue. Again there was no indication of a failed actuator, no codes, and it was moving with command and matching the command from 0-95%.
