08 Hyundai Veracruz
- mobileauto
The fuel trims were good on long and short termand mass air flow performed like expected and could not find any vaccum leaks, it would make the check engine light flash when driving.
Now for the rest of the story, I am fairly new with a scope, could not get to the #5 coil so I changed the plug and coil with another cylinder, no change. found a connector for #1, 3, and 5 injector, scoped the injectors 1 at a time, all looked the same and appeared to be a good pattern I did it both ways. long story short I could not pin point a problem, changed that injector and fixed it and have no idea what I should have seen on the scope-can anyone explain it to me?? thanks for your time
- Desmond6004
- mobileauto
- Paul P.
- Thank you received: 195
All of the waveforms could very well have looked the same. A scope can't see 'dirt' that doesn't cause an increase in resistance to the injector coil.
Hindsight is 20/20, but an injector balance test would have identified that injector as being 'different' or 'suspect' from the others. This would have been my next step after performing everything you already did.
The only other test I like to perform is a relative compression check just to ensure there are no compression, timing, issues when dealing with misfires.
You performed very good troubleshooting!
Never stop Learning.
- GeekDIYMechanic
- mobileauto
- Desmond6004
I read this article yesterday www.searchautoparts.com/motorage/drivabi...ent-misfire-concerns which suggests that if you monitor the downstream O2 sensor it will show rich when the misfire occurs if it's a spark problem and lean if it's amobileauto wrote: I did do it both ways just did see anything weird and wanted to go ahha i see the problem, I still got to the end just wanted to see it
fuel problem. It would be interesting to replicate the problem (might try that myself sometime) and see how it works.
Otherwise, I'm with Weycraze. An injector balance test likely would have pinned this down, but I don't own one. :silly: If you're game for experimenting with your scope, I've had decent results from using a knock sensor on fuel rails to identify injectors that aren't operating. Not saying it would have shown you the problem on this car, just another tool in the box.
www.scannerdanner.com/forum/diagnostic-t...-a-knock-sensor.html
- cj1
- Thank you received: 12
- Paul P.
I cant wait to try this on a known good vehicle for testing!
Sweet
- mobileauto
I know I have got myself way off track somewhere, cant see the forest for the trees, if someone has seen this before great but I am hoping someone can shove me in a direction to start to get a handle on this
sorry for the long post and thanks in advance
- mobileauto
the dam thing was full of water. I am guessing after I gave it back to her the last time it ran fine until she bought gas and here I am.
I drained the tank, replaced the pump and so far no more problems
- mobileauto
