2017 toyota tacoma 3.5 111k miles
  • chief eaglebear
  • chief eaglebear's Avatar Topic Author
8 months 2 weeks ago - 8 months 2 weeks ago #92612 by chief eaglebear
2017 toyota tacoma 3.5 111k miles was created by chief eaglebear
Hi when I started on this vehicle the maf was under reporting at 2.5 I changed kn air filter and it went to normal not sure if thats what did it but it is reporting right now I originally had a random MF on all cylinders which were going away when you revved engine up or at a high idle ok well that condition seemed to go away , I did see 4 and 5 were the predominate misfires that stayed ! I swapped both coils with other coils and the misfire did not follow and is still on 4 and 5 , one thing I did was an injector cutout test on the port injectors and for some reason the scan tool only gave me 4 cylinders to test but while cutting injector 4 there was no change in RPM , my next step actually is to do a propane vacuum leak test just so I can rule out a sneaky vac leak and then im gonna swap the injectors into other cylinders and see if the lazy fuel issue is solved,  I do want to do a injector waveform but I dont think we have an attenuator im not sure if I need one with the snap on Triton? any input is appreciated tommorow im gonna do the vacuum test and then do some swaptronics......and remember.   ....DONT BE A PARTS CHANGER .....Scanner danner for life sa 🤣🤣🤣🤣😃
Last edit: 8 months 2 weeks ago by chief eaglebear.
8 months 2 weeks ago #92614 by Noah
Replied by Noah on topic 2017 toyota tacoma 3.5 111k miles
You will be safe to check the injector circuits with your Triton, no attenuator needed.
While you have the scope out, I like a relative compression test any time I have a misfire complaint. Keep us posted 👍
  • chief eaglebear
8 months 2 weeks ago #92615 by chief eaglebear
Replied by chief eaglebear on topic 2017 toyota tacoma 3.5 111k miles
Thanks noah
Time to create page: 0.266 seconds
