2001 dodge ram v8 5.2L
  • frankiedon450
  • frankiedon450's Avatar Topic Author
10 months 1 week ago #92440 by frankiedon450
2001 dodge ram v8 5.2L was created by frankiedon450
 hi   my dodge ram fuel trims:  When the engine is cold in open-loop what should fuel trims read?   my dodge ram STFT is positive 29% while the long term is neg 24% at idle in open-loop engine first started cold but they come back into specs as the engine warms to normal temp and become LT neg 8 or so and ST switches nicely around  zero .......should i be looking for a problem with the trims so far out at idle cold open loop or is that what the fuel map runs at?    thank you    Frank
10 months 1 week ago #92443 by Noah
Replied by Noah on topic 2001 dodge ram v8 5.2L
Frank,
My first impression is that this is to be ignored. Likely as you said a reflection of the warm up fuel map, or even just a place holder number. As long as the trims are good in closed loop operation and the truck isn't setting trim related trouble codes, I would not think there to be a problem
  • frankiedon450
10 months 1 week ago #92447 by frankiedon450
Replied by frankiedon450 on topic 2001 dodge ram v8 5.2L
Thank you for the prompt response Noah, im glad to hear its not a problem...Frank
