2016 lincoln MKC 2.3l turbo P0172
  • ptebo1
  • ptebo1's Avatar Topic Author
11 months 4 days ago - 11 months 4 days ago #92392 by ptebo1
2016 lincoln MKC 2.3l turbo P0172 was created by ptebo1
Hello, im having some trouble diagnosing a fuel trim issue. Got a P0172 fuel system rich. Someone else already replaced the upstream air/fuel sensor and downstream o2 sensor. Vehicle is not a flex fuel vehicle. I pumped all fuel from it anyway. I reset the KAM and test drove for 15 miles. That did not help. Ive got -30% total trim at idle and -6% total trim cruising. Deceleration fuel cutoff moves the A/f sensor Milliamp data pid to 2800. It will also swing full rich -2800 Milliamp after a KAM reset until the fuel trims stabilize it to around -30 milliamps. I believe the A/f sensor is working. Ive pulled the pcv breather hose off and found no change. I dis-connected the high pressure fuel pump per ford service info and the fuel rail data pid is within spec @ 110 p.s.i per ford supposedly meaning the frp sensor is ok. The map sensor reads 14.6 psi koeo and 4.2 psi koer i performed the ford fuel injector flow test and it measured all 4 fuel injectors in spec at 140. I removed the high pressure fuel pump and it does not appear to be leaking but is kind of hard to tell. I checked the air filter and for obvious air intake restrictions. Ive disconnected the purge valve hose, no change. Ive got a high pressure pump and 4 fuel injectors on order for Friday but I have my doubts. WonderIng if anyones got a silver bullet for this thing or ideas.
Last edit: 11 months 4 days ago by ptebo1.
11 months 4 days ago #92395 by Chad
Replied by Chad on topic 2016 lincoln MKC 2.3l turbo P0172
With the engine hot, stop the engine and watch the fuel rail pressure. KOEO, does Rail Pressure slowly rise, or fall? Heat from the engine should make the pressure rise. If it falls, that would be an indication of a leak.
  • ptebo1
11 months 3 days ago #92404 by ptebo1
Replied by ptebo1 on topic 2016 lincoln MKC 2.3l turbo P0172
Code:
the high pressure fuel pump came in today. I changed it, and oil. Problem solved.
