2015 Mazda BT50/Ford Ranger surging under light load.
- Paul6004
- Thank you received: 9
7 years 9 months ago #26186
by Paul6004
2015 Mazda BT50/Ford Ranger surging under light load. was created by Paul6004
3.2l Ford ranger P5AT direct injection turbo engine.
At around 50km/hr and 70-80km/hr the revs bounce about twice per second , only about 100 rpm like from 1500-1600-1500-1600rpm.
This only happens under light load especially from 70km/hr to 80km/hr.
I watched the graphs for EGR and revs and saw they were similar and unplugged the EGR to make sure - but it still does it with no EGR
command so not caused by the EGR. I smoke tested the intake and there were no leaks.
Fuel rail pressure shows the same bumps as revs - I'm not sure if there should be such a response in rail pressure or if it is actually causing the
problem?
problem?
- Landroverman1958
- Thank you received: 17
7 years 9 months ago #26192
by Landroverman1958
Replied by Landroverman1958 on topic 2015 Mazda BT50/Ford Ranger surging under light load.
Hi good morning,what is the rail pressure doing during the fault?see if yu can graph the rail pressure desired against actual plus air flow desired against actual air flow.it might be a relearn for the metering valve a relearn,pilot relearn,they fit the same engine in the transit.
7 years 9 months ago #26200
Replied by Andy.MacFadyen on topic 2015 Mazda BT50/Ford Ranger surging under light load.
Relearn sounds a good to me , although any common rail surging I have seen was fixed with egr cleaning and a couple of bottles of injector cleaner.
- Paul6004
7 years 9 months ago - 7 years 9 months ago #26201
by Paul6004
Replied by Paul6004 on topic 2015 Mazda BT50/Ford Ranger surging under light load.
Thanks for the replies - this morning the transmission made a bit of a 'clunk' when I took off for a test drive so I took it in to the transmission shop and we went for a drive while he monitored live data - apparently the torque converter is slipping.
Regarding the fuel rail pressure - yesterday I monitored "desired" vs "actual" and it was spot on. What was interesting is that on my budget Nexpeak NX501 I could see the revs and fuel rail pressure pulsing in time with each other but the Snap-on Solus and Autel Maxisys both smooth them out.
Looks like this 3 year old vehicle needs another transmission (at 164000km)
Last edit: 7 years 9 months ago by Paul6004.
- Landroverman1958
7 years 9 months ago #26208
by Landroverman1958
Just a thought,,, maybe you have an torque speed input problem which is upsetting the ecm corrolation with the engine rpm,
- dhausler
6 years 11 months ago #34947
by dhausler
Replied by dhausler on topic 2015 Mazda BT50/Ford Ranger surging under light load.
Did you find out what was the cause, I also have a 2013 Ranger 3.2 which is doing the same.
dave
dave
- TonyLom
6 years 6 months ago #38782
by TonyLom
Replied by TonyLom on topic 2015 Mazda BT50/Ford Ranger surging under light load.
Hi Tony
i have same problem with customers bt 50 surging at 1500 any solution we have done injectors fuel line and checked switches on clutch and excillirator.
- John Curtis
- Thank you received: 111
6 years 6 months ago #38783
by John Curtis
Replied by John Curtis on topic 2015 Mazda BT50/Ford Ranger surging under light load.
Monitor MAP while using a scan tool or a jumper wire to open the EGR valve. A fully open EGR valve should cause the engine to run rough or even completely stall.
- grayham
6 years 5 months ago #39780
by grayham
Replied by grayham on topic 2015 Mazda BT50/Ford Ranger surging under light load.
hi did you find out what the problem was i have all the same things with mine.the gear box is a $5000 job but i need to fix the surging first .desparate to find out
