2019 ford ranger dtc P0420 & P0406 egr A flow excessive and EGR sensor "A" circuit high
  • Peterpaul
  • Peterpaul's Avatar Topic Author
1 year 2 months ago #92129 by Peterpaul
with a component engine tester I was able to electrically test the DPFE and EGR wiring . all is good 5v and resistance  check.
Is there anything else that I can view on the scanner to see if the DPFE or the EGR valve is bad . I'm trying to test and not guess.
1 year 2 months ago - 1 year 2 months ago #92130 by Noah
Wow, I didn't think there was an EGR valve on any modern gasoline engines.
I'm not familiar with that vehicle or system, but I would look for a bidrectional test with the scan tool and see if the DPFE value changes with EGR steps and also if the engine begins to run rough. I'll link in some YouTube videos of Scanner Danner testing older Ford EGR systems. If it's still the same basic idea, DPFE signal voltage should be 0.5v-1.0v @ idle with no EGR Flow, and over 4v with and open EGR.
youtube.com/playlist?list=PLAFYVCyenqcrq...&si=aIEytAZdNXw08ABn
Last edit: 1 year 2 months ago by Noah.
