Code 83 1994 chevrolet s10 4.3
  • Lromeroe#$
  • Lromeroe#$'s Avatar Topic Author
  • Mexican learning English and auto electronics
1 year 3 months ago - 1 year 3 months ago #91989 by Lromeroe#$
Code 83 1994 chevrolet s10 4.3 was created by Lromeroe#$
I get confused what to do with the code 83. Should I check the transmision tcc or the computer prom. I could be wrong please help. I hope you understand me. Thank you
Last edit: 1 year 3 months ago by Chad. Reason: Removed "private" status.
1 year 3 months ago - 1 year 3 months ago #91990 by Chad
Replied by Chad on topic Code 83 1994 chevrolet s10 4.3
Key on, engine off: Do you have battery voltage on pin E10, connector 2 of the PCM?
With the key turned off, check the resistance of the TCC solenoid. This can be done by using an ohm meter on pins "E" (pink and black wire) and Pin "T" (tan and black wire) of the transmission wiring harness. Compare the resistance of the TCC solenoid to the resistance of one of the other shift solenoids. Resistance should be between 10 and 20 ohms.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
If you have an oscilloscope, you can manually energize the solenoid and look for a voltage spike on the TCC control wire. Compare the voltage spike to the voltage spikes of the other solenoids.
  • Lromeroe#$
1 year 3 months ago #91997 by Lromeroe#$
Replied by Lromeroe#$ on topic Code 83 1994 chevrolet s10 4.3
Muchas gracias por ayudarme en el código 83, todo fue un éxito. Se arregla el problema. Feliz día
