1959 Ford galaxie backing lights
  • Paul6004
  • Paul6004's Avatar Topic Author
7 years 9 months ago #26066 by Paul6004
1959 Ford galaxie backing lights was created by Paul6004
Here's a complicated one for you guys :) We don't see a lot of these in New Zealand.
It looks like the reverse switch is perhaps on the steering column in the engine bay but
fuses are hidden all over on this vehicle - where will I find the fuse please?
7 years 9 months ago #26068 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 1959 Ford galaxie backing lights
Based on experience with UK Fords of this era and that Ford did things much the same way in all markets for decades then it is possible the circuit isn't fused, or there are just two fuses. Is it a manual or automatic ? Either way check wire colour at the rear lights and look for it on the steering column switch or gear box.
  • Paul6004
7 years 9 months ago - 7 years 9 months ago #26069 by Paul6004
Replied by Paul6004 on topic 1959 Ford galaxie backing lights
Thanks Andy, it's an auto, I found the two thin black wires going to the switch in front and powered one up and got reverse lights - the other one goes to a 3 way junction and disappears into the harness.
When I powered the first plug I thought it was, the starter cranked - not too safe I suppose :)
Last edit: 7 years 9 months ago by Paul6004.
7 years 9 months ago #26075 by Andy.MacFadyen
No 12v supply at the switch key on ?
No other ignition switched items not working ?
This was the only Ford wiring diagram of that era I could find that included back-up lights not easy to follow but it gives you the wiring colours.
www.oldcarmanualproject.com/tOCMP/wiring...rd/MWire5765-201.jpg
7 years 9 months ago #26077 by Andy.MacFadyen
After a bit of googling the fuse is in the light switch it also supplies the turn signals
  • Paul6004
7 years 9 months ago #26080 by Paul6004
Thanks very much for the effort Andy, that's very helpful. I only saw two fuses on the back of that switch but I might have to get my head deeper in there and use the mirror as well :)
