2007 hhr p1174 code
  • Hurst2001
  • Hurst2001's Avatar Topic Author
7 years 9 months ago #25983 by Hurst2001
2007 hhr p1174 code was created by Hurst2001
Got a 2007 hhr 2.4 and have a p1174 code and something to do with fuel trim .. just asking if some had a fix for it .. car runs good starts up fast when I clear the code it comes back in about 60 miles .. so is it a sensor or any suggestion..
7 years 9 months ago #26002 by Tyler
Replied by Tyler on topic 2007 hhr p1174 code
The dreaded P1174! :lol: This code is kinda a pain, TBH.
The code definition is Fuel Trim Cylinder Balance Bank 1. The PCM is using the upstream O2 to detect lean running cylinders, and flags this code when one or more cylinders reaches a calibrated threshold.
To be clear, this is NOT a fuel trim issue. You can have excellent fuel trims and still flag this code. Basically, anything that can make the engine run lean (without setting a lean code) , or anything that can cause a misfire (without setting a misfire code) is fair game. Even the O2 itself can cause this code.
The calibrated threshold that the PCM uses to flag this code isn't in the scan data, so you're on your own to figure out which cylinder is causing the issue. Use the freeze frame data as a guide to when the code sets, and monitor the misfire counters to see if one cylinder or another counts up.
  • Hurst2001
7 years 9 months ago #26015 by Hurst2001
Replied by Hurst2001 on topic 2007 hhr p1174 code
Yes it might be the o2 or maybe vacuum leak or a injector .. going to shop in two days and replace plugs there dew and then check exhaust for leaks before bank o2 and scan the car .. it’s a pain but got to nail it ..
7 years 9 months ago #26033 by Desmond6004
Replied by Desmond6004 on topic 2007 hhr p1174 code
Maybe ask them for the spark plugs - in order, so you can see if any are a different colour. I normally poke some holes in a box and number them when I remove spark plugs. Perhaps give them a box with holes to insert the plugs in line with the relevant cylinders to aid diagnostics.
7 years 9 months ago #26058 by Tyler
I happened across an excellent GM TSB for this code as well, talking about replacing fuel injectors. B)
File Attachment:
File Name: hhrfuelinjectors.pdf
File Size:45 KB
Definitely something to consider if you don't find any other obvious issues.
