2000 dodge dakota 4.7 Cranks no start cam signal is at 7-8v
  • chavez96
  • chavez96's Avatar Topic Author
7 years 10 months ago #25349 by chavez96
so i have replaced the pcm. i got a re-man pcm, since this car had no 5 v. reference to cam and crank sensors. my scan-tool
wasnt able to scan the truck and didnt crank.
now that i have the pcm with the vin the car cranks but wont start.
checked the cam crank signal and found that crank signal is 7-8 volts.
has any one had this problem?
7 years 10 months ago #25357 by Tyler
Are you sure about your scope connections in this capture? Because it sure looks like the green trace (CKP) is just following battery voltage during cranking. The abnormal green trace is what I usually see while trying to scope a Hall effect sensor with a weak ground connection.
Are you missing spark and injection pulse? Any codes stored? IIRC, this engine can start and run on the CMP sensor alone.
7 years 10 months ago #25358 by Matts Auto
Looking at wiring diagram that is same 5 v reference for tps, map & cam sensor on orange wire. Do you have 7-8 volts at Ecm pin 17 as well ?
  • chavez96
7 years 10 months ago - 7 years 10 months ago #25367 by chavez96
At times I get p1391CMP or CKP Signal Intermittent Condition. I checked for spark and nothing. I am sure that am in the signal wire the diagram says gray with black for ckp signal.
Last edit: 7 years 10 months ago by chavez96.
  • chavez96
7 years 10 months ago #25368 by chavez96
Need to check that.
