False positive OBD2 codes on hand held scanners
- Retired
Did you also get the common P1624 Snap Shot Data Stored?
- Retired
i used a innova 3100j on saturn OEM enhanced mode. No global ODB2 codes noted.
All these
P0137 P0131 P0132 P0133 PO134 P0141 P0138 P0140 P1133 P0571
- Retired
Quick side question, I just ordered the blue reader Bluetooth OBD2 scanner, have u heard anything about them?
OBDLink ones are the very best but $$
None of them will read airbag or ABS systems only power train.
The software App used is critical most Android users use Torque which looks great but is tedious to use for diagnostics. For Android look in the Google App store for the app that is now called inCarDoc it is much better for diagnostics.
For Windows in the MS Windows store you will find Car Scanner ELM327 OBD2.
All these software have pro versions for very low cost.
Retired wrote: Thank you
Do you mean BlueDriver? I've never used it, but I've heard great things from others. It's graphing capability seems to be excellent.
Agree with Andy, Torque is garbage. :lol: Torque Pro is no better. OBD Auto Doctor is another good alternative.
Retired wrote: P0137 (Low voltage B1S2) P0131 (Low voltage B1S1) P0132 (High voltage B1S1) P0133 (Slow response B1S1) PO134 (No activity B1S1) P0141 (Heater B1S2) P0138 (High voltage B1S2) P0140 (No activity B1S2) P1133 (Insufficient switching B1S1)
Do those differ from the definitions the Innova showed you? Because all those sound reasonable for this vehicle. :huh:
- Retired
- Retired
Retired wrote: the o2 sensors are new and they dont have heaters?,,, thanks
The downstream sensor isn't heated? The wiring diagram says it should be, anyway. :silly: Not trying to tell you how it is! Just genuinely confused.
- Retired
