Long term fuel trim -22
7 years 10 months ago - 7 years 10 months ago #25123 by ianis
Long term fuel trim -22 was created by ianis
Hello,
I have an alfa romeo mito 1.4 t-jet (120PS) with A LONG TERM FUEL TRIM of -22.
Sometimes it gets to -25 and throws a P1172 code.
o2s1 is around 0.8V and o2s2 is around 0.4V at idle. I changed the o2s2 sensor and nothing happend.
Intake manifold pressure: 34 kpa
Last edit: 7 years 10 months ago by ianis.
7 years 10 months ago #25128 by Desmond6004
Replied by Desmond6004 on topic Long term fuel trim -22
ianis wrote: o2s1 is around 0.8V
Does it stay there permanently or move up and down?
I just did a search and found "I've just noticed that your car is a JTS; upper lambda errors seem to be very common with these engines. Mostly it is just the connectors that are the problem; I believe the Dealer solution is to solder the (loom) wires to the (lambda) connector."
7 years 10 months ago #25130 by Desmond6004
I'f I'm thinking of the correct system your oxygen sensor 1 should be reading as in this image - if it's stuck on 0.8 the fuel trims will keep going negative to bring it down again and eventually throw the fault code.
