PO715
  • JOHN-DIEFF
  • JOHN-DIEFF's Avatar Topic Author
9 years 11 months ago - 9 years 11 months ago #3112 by JOHN-DIEFF
PO715 was created by JOHN-DIEFF
i HAVE A 2000 FORD ESCORT SE 2.0 ENGINE AND A CODE PO715 SPEED SENSOR CIRCUIT THERE IS A SENSOR ON THE TOP OF THE TRANSMISSION RIGHT IN THE CENTER. DOES ANYONE KNOW IF THAT IS THE SPEED SENSOR BECAUSE I DON'T KNOW HOW MANY SENSORS ARE ON THE TRANS MISSION .THANK YOU -JOHN
Last edit: 9 years 11 months ago by JOHN-DIEFF.
9 years 11 months ago #3122 by Caritech
Replied by Caritech on topic PO715
Try Googling an image of the sensor and source a wiring diagram.
The following user(s) said Thank You: JOHN-DIEFF
9 years 11 months ago #3124 by Tyler
Replied by Tyler on topic PO715
Hey John! Just curious, any luck on your P0340.
pole71 was awesome and posted sensor locations in your P0340 thread, and it happens to have the VSS location on there, too. "On lower rear of transaxle." Seems like the sensor you found on top of the transaxle might be the turbine speed sensor, instead.
Wiring diagram says the VSS has white/black and blue wires:
9 years 11 months ago #3140 by Chad
Replied by Chad on topic PO715
P0715 refers to the input/turbine shaft speed sensor. 2 wire sensor. Red wire and White wire.
Time to create page: 0.506 seconds
