Intermittent non start
- Pj
7 years 11 months ago #24931
by Pj
Intermittent non start was created by Pj
2005 Volkswagen 2,0 TDI (PD injection),automatic. Cranks but wont start intermittently, No DTC , Run engine for 5 min plus switch off, Restart vehcle just cranks but wont start. Key on engine off radiator fan runs on cold engine. Wait approx 10 min vehicle will start or switch Ign on and off a few times. When engine is at operating temp and you switch off, waiting period before she will start approx 30 min to 1hr. While she cranks with non start and scan tool connected, all sensor values/numbers do not show, it is blank.The automatic shift indicator on cluster also flash. Main relays check out okay. When back on vehicle again will be checking power and ground to ECU while there is a non start. Just off the top of head, power to the ECU is being pulled to ground. Any advice would be real welcome
- Desmond6004
7 years 10 months ago #24998
by Desmond6004
Replied by Desmond6004 on topic Intermittent non start
Can you scan the immob system? may be a few clues there.
- Pj
7 years 10 months ago #25014
by Pj
Replied by Pj on topic Intermittent non start
Yes that being the only left, I will definitely chase the immobilizer. Thank you for your response,
- Desmond6004
7 years 10 months ago #25036
by Desmond6004
Euro cars, I don't like them at all! Too much finicky electronics.
Check all fuse connections too. I had an Audi A4 that would occasionally stall and bring up "short circuit to ground" faults on all the major engine components including injectors. I traced it back to a single 25 amp fuse that had a bad contact in the fuse box - burned on the sides. Every now and then it had a voltage drop that made the ECU assume that there must be a short somewhere. Running your hands across the fuses sideways can show up a bad contact.
- juergen.scholl
- Active partschanger
- Thank you received: 462
7 years 10 months ago - 7 years 10 months ago #25038
by juergen.scholl
Replied by juergen.scholl on topic Intermittent non start
The immo system features a lag function. On these # 4 and ยท# 5 iimmo types there is no key identification request after engine shutdown for some 10 seconds on restart. Any key ,even without transpoder, will start the car during this period.
So if the engine does not start IMMEDIATELY after shutown this points into another direction than immobilizer.
Last edit: 7 years 10 months ago by juergen.scholl.
