(FIXED) 1997 Infiniti J30, 3.0 V6, Intermitten RICH Condition on Both Banks
- Seabass86
- Thank you received: 8
Checked for DTC's. Only 3 Stored codes.
-P0400 Exhaust gas ricirculation flow.
-P0325 Knock Sensor Bank 1 Circuit.
-P1443 Canister Control Vacuum Check Switch.
Checked live scan data on idle.
-Misbehaved again while in park and idling. LTFT went full negative (-18 to -25) (RICH) on both banks. Exhaust smelled like fuel.
For those wondering, car does have total of FOUR O2 sensors, 2 sensors for each bank post/pre cat. All four sensors respond to snap throttle. (No fixed signals).
Both banks would switch back and forth from OL-DRIVE to CL when opening throttle. Car will not go into and STAY in CL on it's own.
LTFT were all over the place. Showing normal ranges within -10/+10, then suddenly going full Neg ( -20 to -25) then back again. Not a consistent problem.
One thing I noticed was 170 degrees was the highest I could get the ECT to display. I was hoping to see normal operating temp of around 200-210 degrees.
Took car for a test drive around my neighborhood. ECT temps dropped to 167 degrees and refused to display higher than that. Both banks were still switching back and forth from "OL-DRIVE" to CL even while driving the car up to 45mph.
I've attached a vid and some screen captures. Thanks for any input!
VIDEO
Capture 1
Capture 2
Capture 3
- chief eaglebear
- Thank you received: 70
- Seabass86
- Seabass86
Regulator/Regulator solenoid seems most likely. I'll bypass test the solenoid (easiest to get to) to see if it's working. The regulator itself is buried behind by the firewall... won't be easy to replace.
How do you guys test a stuck closed regulator? Thx.
PHOTO of fouled plugs
VIDEO of car being naughty.
Sry for getting a lil rambly in the vid...it's a bad habit...was a little frustrated with my phone.. didn't have time to edit so just threw it on here. I'm MOSTLY to the point.
Thx again for input guys.
- Seabass86
Still though... Fuel pressure regulator (which is easy to get to, right atop intake runner) is my next check. Will update.
- Desmond6004
Then I had another Nissan that would occasionally run rough and foul up the plugs and sometimes would crank but not start - it was a bad temp sensor. First time I've seen an engine too rich to even start. Live data was showing "-30" when it wouldn't start. Perhaps do an I/M readiness check which may tell you why it won't stay in CL.
With regard to checking for a stuck regulator - I suppose fuel trims are one of the things that will suggest that besides actually fitting a pressure gauge to the fuel rail.
- Seabass86
This car's got two FPR's and with them both disconnected from vacuum, the car continues to exhibit the same symptoms of an exaggerated rich condition. They don't leak any fuel from their vacuum ports either.
Also, as stated before, all four 02's react both rich and lean on scan data when snapping throttle or when changes between OL & CL occur. Which reminds us that once again, this issue, though severe, is intermittent. Just this morning I had a smooth lovely drive around the old cemetery with stable FT trim numbers and no symptoms.
Ideas? It's getting edgy now. The oil reeks of fuel and I think I'm starting to hear a knock develop.
Should I disconnect the ECT sensor and see what happens? Take it out of the equation? Not sure what the PCM"s protocol for that would be.
- Desmond6004
As per my signature this area of diagnostics is still something I'm exploring and trying to improve on and sometimes more experienced people may roll their eyes at my comments but .... I'm trying
- cj1
- Thank you received: 12
Try pinch off the evap purge line to the intake.
Possible excess fuel from evap canister.
- Seabass86
- Desmond6004
- Seabass86
Swapped the oil for some used oil I had laying around. I know that sounds bad, but the oil in the car was over saturated with fuel from cylinder washing..and being thanksgiving, not alot of places were open. I wanted to do my part to protect the engine. But, If I fix this car, i'll put some fresh oil in her.
Bit the bullet and paid for iATN Premium, then proceeded to get busy with it. Here's what I found when narrowing down my search results to Infiniti J30 cases where all plugs were fouled. (That's the symptom which stuck out the most.)
None of the fixes reported involved the ECT or the MAF, despite them being solid theories. Nor did they involve the FPR's .
The most mentioned fix ( in 3 or 4 cases IIRC) had to do with timing. Either from an improperly set base timing that was retarded too far (the cam sensor on this car is adjustable by hand for setting it) or because of a physically damaged cam gear drive (which engages the "sensor drive".
Craziest cam sensor I've seen. The sensor, pick-up/internal electronics, bearing and shaft are all one piece. It's basically a distributor.. but not really... (the engine is coil over plug ) very weird design. It's official name is the "Crank Angle Sensor". The engine doesn't have cam crank sensor. Just this Crank Angle Sensor. Any theories as to why it's called that?
Anyway, went out, pulled the sensor, inspected the shaft/splines (there were reports that rust damage can cause rounding of the splines & therefore erratic timing). Mine looked good, some old gooey grease, but no rust. So I cleaned it, lubed it, put it back in, then grabbed my timing gun and fire her up.
Long and behold, timing was retarded big time. The mark jumped around a bit between -15 and -20 degrees. This engine should be set at 15 degrees of advance at idle. That may very well explain the so-called "over fueling" and why the cylinders were being washed, causing all the plugs to foul and the raw fuel smoke out the tailpipe. i moved the "crank angle sensor" clockwise to it's travel limit. That got the timing mark where it needed to be at 15 degrees advance and the engine seemed to stabilize ( i really hope it wasn't my imagination).
Sadly, I couldn't run the engine longer than 5 or 10 minutes. My phone was blowing up because my friends were waiting for me to join them for Thanksgiving dinner. So...had to stop everything and clean up for the day.
But Tomorrow I'll pick back and see if she stays stable, and go for a test drive with scan tool in tow. Crossing my fingers.
- Seabass86
Yes, base timing was off, and I adjusted it to spec.
No, it was not the cure. Engine is smooth and consistent when cold, but fuel wash occurs soon after and it chugs horribly and stalls.
All four 02's report full rich when this occurs. I rechecked them for response and they respond accurately to Clear-Flood cranking by leaning out.
Fuel delivery is back on the table again. Given this car's reputation for injector failures, it's possible both banks have a stuck injector or more.
Will test fuel pressure today and report back.
Purge is out IMO, unless there's raw fuel in the canister AND the purge is stuck wide open.
FYI, skip any of the fuel trim PIDs that have B1S1, B2S1, B1S2 and B2S2 in them.
- Seabass86
Pulled up MAF voltage KOEO and voltage was all over the place. Wouldn't hold a steady line. Then tried to start the car. It was really tough to keep it running and was smoking bad before stalling again. Then unplugged MAF to see what would happen.. car doesn't like that so it wouldn't start.. Then I plugged it back in. MAF Voltage was steady at 200 mv. Wasn't jumping around everywhere.
Car fired right up and idled normally. Test drove car and drove normally. Brought the scanner with me on the drive, MAF voltage was sweeping and returning smoothly with throttle changes.
Wow... the difference between Generic OBD and factory is night and day. The "calculated" MAF value was slow to refresh even when isolated to a single PID.
Thank you Tyler!
Really? :huh: Red flag for the MAF. This is where I'd suggest some direct testing at the sensor itself. Either watch the signal on the scanner while wiggling the connector or tapping lightly on the sensor, or get your DMM out and compare what you're seeing on the scanner to actual.
It's crazy how heavily Nissan/Infiniti products rely on the MAF. :silly: Their backup strategies are very weak compared to other makes. I'd say you disturbed a connection at the MAF when you cycled the connector. That's why it performed well on your subsequent test drive.
- Seabass86
Checked wiring integrity, which checked out. Knocking strictly on the MAF housing was what made it squirm around.
I agree, weak strategy. More than just a weak strategy, its dangerous. It can melt your cats and cause oil contamination.. yikes. I still don't know if the cats survived this ordeal.
Replaced the MAF with a new one. Changed oil&filter and replaced spark plugs. Car is fixed. (Except for possible cat damage now..). Thanks to everyone who chimed in! :woohoo:
Thnk you Master Tyler!
Unfortunately, it's not only the backup strategy that's weak, but the MAF fault detection.
FWIW, I bet the cats survived.
Also, thanks to you, I now know that the VG30 appeared in cars other than the 300ZX. :silly: Honestly didn't know that before watching your video!
- Seabass86
The J30 (known as the Nissan Leopard J Ferie in Japan) is a real oddball of a car. Rear drive mid-size, dense (feels like an ingot), and oddly styled. The Auto was the only trans option. That and it's relative heft is what kept the VG30 from really shining on this model. Otherwise, a neat car.
Thanks on the 908. Got it used for $725 at auction when a local shop closed it's doors.
