2001 Saturn SC1 - 1.9L 4-116 SOHC - P0410
- TomPearce
7 years 11 months ago #24789
by TomPearce
2001 Saturn SC1 - 1.9L 4-116 SOHC - P0410 was created by TomPearce
Hello,
I recently bought a 2001 Saturn SC1 from a lien sale and have been fixing it up. The last issue that I need to fix is the P0410 code for the secondary air injection system. I have done a lot of research on this issue, and found some great videos and such for my specific car. I have worked through them but am still a little stuck. Let me go through what I've already done.
I have checked that the air pump is working properly, the hose from the pump to the diverter is free of obstruction. The solenoid has two vacuum tubes that come of of it, one to the diverter and one to the TBI. Both have vacuum. Some air comes out of the diverter valve, but not a lot. The metal tube that goes from the diverter to the exhaust manifold is clear of obstruction. I have removed the exhaust manifold and cleaned out the channel, as well as the air holes leading into the engine. I have replaced the O2 sensor.
I am thinking it might be the diverter valve itself. If I hook up a vacuum pump to the vacuum nozzle on it, it creates vacuum on the air pump side, and the exit port doesn't seem to be effected at all. I am a computer technician, not a mechanic, but it would seem to me that if vacuum is supposed to be applied to open the valve and allow air to flow from the pump to the exhaust manifold, that applying vacuum manually wouldn't be possible unless I was blocking both the intake port and the exit port.
Also, I am able to suck air in, and blow air out through the hose coming from the air pump, and both ways it goes to/comes from the vacuum nozzle.
Any insight would be appreciated.
- cheryl hartkorn
- Thank you received: 130
7 years 11 months ago #24790
by cheryl hartkorn
Replied by cheryl hartkorn on topic 2001 Saturn SC1 - 1.9L 4-116 SOHC - P0410
do you have a scanner with bi directional controls to turn on the pump and diverter valve? id do that and look for the o2 sensors to go lean when there on. but if not you can watch the o2 sensors when the pump runs. i think your right thediverter valves should have plenty of air coming out of them while the pumpis on.
7 years 11 months ago #24799
Replied by Tyler on topic 2001 Saturn SC1 - 1.9L 4-116 SOHC - P0410
I think you're correct in your suspicions about the diverter valve. With the pump on and the valve open, there should be tons of airflow going to the exhaust tube. If no amount of vacuum pumping will get it to flow, then it's done. :lol:
The one thing that bothers me is how both vacuum hoses at the solenoid have vacuum? :huh: I figured that the solenoid would be normally closed, and only open when secondary air is desired. Does the diverter valve have vacuum at all times? Or did I misunderstand?
- Ben
- Thank you received: 215
7 years 11 months ago #24806
by Ben
Replied by Ben on topic Re:2001 Saturn SC1 - 1.9L 4-116 SOHC - P0410
I agree with Tyler the diverter valve is toast. But ensure the vsv only has vacuum coming through it when it is energized
- TomPearce
7 years 10 months ago #25129
by TomPearce
Replied by TomPearce on topic 2001 Saturn SC1 - 1.9L 4-116 SOHC - P0410
The vacuum from the solenoid was only present while the air pump was engaged. I ordered the part and installed it, and the issue has been resolved. Finally got the car it's smog inspection and it's all good to go. Thank you guys for your responses.
7 years 10 months ago #25134
Very nice.
Glad to hear it's all fixed up!
