Hello I'm working on a 2002 Honda Civic with the 1.7L. starts and idels, but has no power. It felt like a clogged cat but no excessive back pressure ( around d 1pis). Can anyone show me a good cam crank correlation. The customer does not want to pay to have the timing cover taking off to check the timing. Any help would be appreciated thank you.
Did a manifold vacuum test and only had about 12inhg, another indication the timeing was off. Took cam cover off and found The timing was off I will post good cam crank correlation soon.
this is the bad one
this after the fix.
Thank you all for the help haha. Hope these waveforms help some one.
Last edit: 7 years 11 months ago by Dmichnick. Reason: Fixed
I have to ask, did you try a relative compression test with an ignition trace when the customer did not want the cover removed? Or you just went ahead and pulled the cover?
