P0720 2005 Dodge Ram 2500 5.9
  • DirtyHarry
  • DirtyHarry's Avatar Topic Author
9 years 11 months ago #3044 by DirtyHarry
P0720 2005 Dodge Ram 2500 5.9 was created by DirtyHarry
I could use some help identifying a output speed sensor on a 2005 dodge ram 2500 4wd diesel. It is located between the automatic transmission and transfer case and is a two wire sensor. What is the best way to tell the difference between a two wire hall effect and a variable reluctance sensor. Is there a good video that has covered testing a two wire hall effect. Thanks for any and all help.
9 years 11 months ago #3049 by Noah
Replied by Noah on topic P0720 2005 Dodge Ram 2500 5.9
Alldata was little help :/
The component test meter of the Verus describes this as a two wire magnetic pickup sensor.
So you're just going to be looking for an A/C sine wave, like a wheel speed sensor.
It also says that the sensor is not used for vehicle speed, only for governor pressure calculation.
This video shows how to test a two wire VRS type sensor.
9 years 11 months ago #3051 by Tyler
Replied by Tyler on topic P0720 2005 Dodge Ram 2500 5.9
DirtyHarry wrote: What is the best way to tell the difference between a two wire hall effect and a variable reluctance sensor.
Good question! I don't know if Paul has covered this in any videos, someone correct me if I'm wrong.
On every 'digital' speed sensor (AKA magneto resistive) I've ever seen, the sensor always has one 'power' feed going into it, 9V or higher. No variable reluctance sensor I know of uses a bias voltage that high (usually 5V or less), so I'll use the initial voltage readings as a guide to what kind of sensor I'm looking at.
9 years 11 months ago #3065 by Noah
Spot on sir!
9 years 11 months ago #3067 by Tyler
Noah wrote: Spot on sir!
Crap, does Paul say that in the video? :blush:
