2007 Lexus IS350 fuel trims question
- TonyOle26
- chief eaglebear
- Thank you received: 70
- chief eaglebear
Before we go wild with diagnostics, were you doing any repairs under the hood? No insult meant, it's just easy to leave a hose off during repairs and end up with fuel trim issues. FYI, nothing you were doing with the downstream sensors or the catalytic converters will cause this.
Standard fuel trim theory applies. When was this reading taken? If you saw these numbers at idle, raise the RPM to 2500 and check again. If they're significantly better, you're looking for a vacuum leak. If they didn't improve much or got worse, you're looking for a fuel delivery issue.
- Paul6004
- Thank you received: 9
Just a question, how long does it take for long term fuel trims to be set? Can it happen right after leaving a hose off and idling the vehicle for a while?Tyler wrote: Before we go wild with diagnostics, were you doing any repairs under the hood? No insult meant, it's just easy to leave a hose off during repairs and end up with fuel trim issues
- Paul6004
I might have to actually do a test one day - check long term trims then unplug an air line and watch how it changes.
- TonyOle26
- TonyOle26
TonyOle26 wrote: A little background. This is my son-in-law's car so I don't have ready access. It required a new fuel pump last January. it was replaced and the shop said that there was low pressure but that their tester was bad. (So how could I believe the tester?)
Do you recall if it was the high pressure pump (at the engine), or the low pressure pump (in the tank)?
This past July just before emissions test it popped a P0137 code. So I changed the O2 sensor. (Bank 1 sensor 2). It passed the emissions test. Then about 3 weeks ago the P0137 popped up again, this time with a P0430 (converter inefficiency). Since the O2 is warranted I replaced it again. Things seemed fine. Now the P0430 popped up again.
Gotcha. Thank you for the history!
I will probably get my hands on the car this weekend and try viewing the data at 2500 rpm and WOT. Also check for any and all vacuum leaks.
Let us know what you find.
If all looks good, what are the chances a fuel pressure regulator is kaput? Like I said car runs great. No bogging when flooring it at idle, etc and it has fantastic pickup.
Unlikely, IMO. Aside from Toyota Sienna's, Toyota/Lexus fuel pumps rarely fail, in my experience. Not debating the last shop that changed the pump, just doesn't happen often. :silly: I'd also suggest putting the P0430 aside for now and concentrate on the trims. Once the trims are back in line, rerun the cat monitor and see what comes back.
Because you're not the driver, you might also ask your son-in-law if he's using E85. :blush: No insult meant, but it'd very quickly account for the lean trims.
- TonyOle26
- TonyOle26
The principle is to accelerate through 1st and 2nd gear at wide open and observe the upstream sensors. They should show rich. If they do, the fuel system is capable of keeping up with high demand. If they don't, then we dig into inputs (MAF), pirate air, and fuel delivery.
On this IS350, you're going to see the upstream air/fuel sensors represented by current data PIDs instead of O2 sensors with a 0-1V range. Not a problem.
Ideally, both upstream sensors will show -1 mA at wide open. Equivalence Ratio PIDs will hopefully show .900 or less.
You can also observe Calculated and Absolute Load under the same conditions to gauge engine breathing and air measurement issues. Both should clear 85% at wide open when close to redline. Low Load indicates a breathing issue (unlikely since you noted the engine has good power), or a measurement issue (more likely, because of the lean trims).
- TonyOle26
