O2 sensor signal over 1v
  • jeoff82
  • jeoff82's Avatar Topic Author
7 years 11 months ago #24188 by jeoff82
O2 sensor signal over 1v was created by jeoff82
I have a 1991 Ford Escort that I suspect is running rich so today I probed the 2 upstream Lambda sensor signal wires with my Vantage Pro and found between 1.14-1.20 volts on the signal wires. Is it possible for narrow band o2 sensors to produce a 'high' voltage like this, I always thought 900mv was around the limit of rich? The voltage does not change from first startup to running up to temp.
7 years 11 months ago #24189 by juergen.scholl
Replied by juergen.scholl on topic O2 sensor signal over 1v
This type of O2 sensors shows this voltage when they are shorted to positive . Even when you short it to 12 V it woon't show more due to the way how the ecm processes the information.
The following user(s) said Thank You: Andy.MacFadyen, jeoff82
  • jeoff82
7 years 11 months ago #24190 by jeoff82
Replied by jeoff82 on topic O2 sensor signal over 1v
Shorted to positive possibly from the heater circuit?
7 years 11 months ago #24193 by juergen.scholl
Disconnect the O2 sensor connector and watch your scan tool reading. If the 1.2 volts go away the fault most probablyis within the sensor.
7 years 11 months ago #24232 by EricGoodrich
Replied by EricGoodrich on topic O2 sensor signal over 1v
A general rule of thumb for any feedback device is that any values outside a normal range indicates an open/short circuit.
Think of a 5v reference circuit. A map sensor. Operating range might be 0.5v to 4.5v. why not 0v or 5v? Those values are reserved for circuit testing by the ECM.0v might indicate a short and 5v might indicate an open, the ECM then sets the DTC. Not always, sometimes they're dumb. But, if you see an oxygen sensor with values outside of normal range, expect a circuit problem.
The following user(s) said Thank You: Noah, jeoff82
