2009 Mercury Mariner P0302 Misfire Code-- Tried Everything I know of!
- Novice3319
--replaced all valve cover gaskets
--replaced spark plugs and boots on coil packs
--compression test on all cylinders, with all coming in at 120
--checked all fuel injectors
--switched coil packs on #2 and #4 to see if the code would be P0304 signaling that it would most likely be the pack
The car is sluggish when idling in drive, and also around 45-55 mph
Any other items that should be checked? It's a great vehicle-- has 178K miles on it and the transmission has around 90K on it.
- Ben
- Thank you received: 215
- juergen.scholl
- Active partschanger
- Thank you received: 462
- Novice3319
Ben wrote: The code won't change immediately. Do a cylinder drop test you can unplug 1 coil at a time until you find the cylinder that isn't firing. (it may not be number 2 companion cylinders can flag incorrectly) after pinpointing which cylinder it is move the coil and or plug to another cylinder and do cylinder drop test again if it follows coil or plug then you know what it is if it does not follow then you could try same thing with injector or verify wiring integrity
Just talked to the guy that worked on my vehicle, and he says they did that. Any other suggestions? Could it be electrical, wiring, etc.? Thanks again for your response.
If it's the 3.0L, then #2 is the underneath the intake, correct? Is that the coil that your mechanic has been moving around, or was it a different one?
- Novice3319
I say back up and come at this from scratch. Get someone else in the driver seat and get the engine running rough in drive. Go out to the engine and do a power balance test to make sure #2 is the weak cylinder.
While you're there, do a quick audible relative compression test. Your mechanic measured 120 PSI on all cylinders, which sounds low to me. Floor the gas and crank the engine, listen for a skip. Take a phone video and post if it you're not certain.
How were the injectors checked, exactly? Consider moving #2 to another cylinder if the power balance test works out and the relative compression shows no issues.
- TheGrinch
Were you ever able to get this resolved or a find a final diagnosis?
Having the same issue myself, thanks!!
