04 Mazda6 2.3 CRANK NO START! SOLVED!
- MBMazda
- MBMazda
- Carstuff
- Thank you received: 19
- MBMazda
Think I’m going to check 12 volt ref behind the PCM plug with KOEO and see. If so I will bypass the harness straight to the plug and see if that’s it. Going to watch some more scanner vids on how to test that properly. Wish me luck.
Thanks for chiming in.
- MBMazda
So here is where I am, I need some help on where else to test.
I backprobed the PCM connector signal wire for the CKP and got a steady 2.5 volts with KOEO. When cranking it, I get 2.8 steady. I have continuity in both ground and signal from the harness to PCM. Just thought I would try this test in case I wasn’t testing properly and because the damn component tests on prodemand say it should have a 12v ref on KOEO.
I’m lost as to what’s up with this thing and if I should even be getting a 12v ref on a two wire Hall effect sensor.
- fudgie
- Thank you received: 4
- MBMazda
The seller is out right now so waiting for him to get back to me. We have been talking off and on and he’s been helpful but swears up and down the motor will work.
- MBMazda
How are the crankshaft pulleys different, exactly?
What year of vehicle did the replacement engine come out of? From what I've found, in 2006 the CKP sensor changed from a VRS (two wire) to a Hall effect (three wire). CMP is the same way. The sensor reluctors are also different.
- MBMazda
When I look up sensors for the 03-05 they are the same as old motor and you are right, as soon as I go to 2006 it’s a three wire. After searching the CKP sensor at autozone to match we found a fusion two wire sensor that fit it. I can’t find when year the motor was or what car it came out of. Confused as hell to say the least but the block says Mazda...lol. I know ford uses L3-VE motors so you guess is as good as mine.
What else could cause a no RPM other than CKP sensor or circuit?
- MBMazda
Before we go down that path, lets back up a bit. No spark and injection pulse? Do the injectors have power during cranking? Do the coils spark at all when cranking? Does the coil pack have power during cranking?
One of the quick indicators of a timing problem is one or two sparks during cranking before it stops completely. It's not a smoking gun, but it can point us in the right direction.
- MBMazda
- Thank you received: 1139
Not throwing doubt on you, but just because you never touched the balancer yourself doesn't necessarily mean that no body did.MBMazda wrote: There is power to the coil pack. No spark at all, the coil pack is good. The fuel pump is good and clicks on to pressurize. There is no way the timing is off. Never touched it. All cylinders have a solid 240 psi.
Is it possible that someone might have removed the balancer to get the engine out and bolted it back on, or maybe even turned the engine backwards during disassembly?
I've seen some strange stuff when it comes to used engines...
If you'd care to post the VIN on the block, I can try to decode it for you
Do you still have the valve cover off? If so, now might be the time to verify mechanical timing. I dug up this Mazda PDF from another thread:
foxed.ca/rx7manual/manuals/NC%20Miata-MX...ming%20Procedure.pdf
Like Noah said, if someone removed and reinstalled the crank pulley, then it's almost certainly out of time. Any witness marks on the pulley bolt?
- MBMazda
I have already looked into the timing procedure. However, when did a small out of time issue ever fail to give RPM’s?
- MBMazda
- MBMazda
Now I have to figure out why she won’t stay running. Think I will recheck all fuses again. Lol.
