Transmission Electeical
  • Jrogers0229
  • Jrogers0229's Avatar Topic Author
8 years 1 week ago #23897 by Jrogers0229
Transmission Electeical was created by Jrogers0229
2003 Dodge B2500 Van.
I have had 2 pcm installed. Pick up coil, cap, rotor, alternator,battery.
The voltage regulator went out of the pcm on a trip. Left me stranded for a few days till we finally figured the bad pcm issue. New pcm installed but still didnt make it home. Had another pcm installed along with the above parts.
About a month later alternator gauge went to 0 and check gauge light came on. I thought the pcm was going out again since that's what it did before. Did not get the 0601 code but I do have several other codes. I will get into those. I did wire in an external regulator and it seems to work. The volt meter doesn't work and the check gauge light and check engine light stays on.
The problem I have run across is the 2 wires that went to the plug on the alternator. One is white/blue stripe and the other is dark green/blk. The white/ blue stripe looks to supply 12v to the trans relay and no matter how I wire it the trans will not shift. I think it's in limp mode. I have not checked 5v reference on the trans plug I just got a diagram for that today will check tomorrow.
I do have the following codes.
1594 voltage too high
0622 field control circuit
0743 tcc solenoid
0753 electrical solenoid A
0713 tranny temp(got on start up today)
1763 Gov pressure too high
1765 12v supply relay
1495 evap solenoid.
I have changed every solenoid in tranny and the wire harness.
The evap solenoid has been changed as well.
Been trying to figure this out for weeks any help would be great.
8 years 1 week ago #23899 by Paul P.
Replied by Paul P. on topic Transmission Electeical
Here is you Alternator Wiring Diagram.
The White wire with the Dark Blue Trace goes to pin 25 of the ECM Connector 3 (Gray)
The other wire the Dark Green goes to Pin 10 of the ECM Connector 2 (White)
Neither of these two wires go to the tranny.
If you need more info let me know
Never stop Learning.
  • Jrogers0229
8 years 1 week ago #23902 by Jrogers0229
Replied by Jrogers0229 on topic Transmission Electeical
This is the diagram I am using. Everything matches up so I am assuming it is correct. I paid for the service to download so it should be. Anyway the wht/drk blu wire is the one in question. Comes off the plug for the alternator and goes to the pcm and the trans relay. I am super confused since I have been looking at this stuff for weeks. Need a new set of eyes maybe. Thx
8 years 1 week ago - 8 years 1 week ago #23904 by Paul P.
You can get all your wiring diagrams here as well.
www.bbbind.com/free-tsb/
The wire in question according to my info goes to Pin 25,PCM Gray Connector 3.
AND, YOU ARE CORRECT, it does provide control power to the trans relay it splits off at Splice 104 which is located...
Wow thats poor on chryslers part not to show that on the Generator diagram, but they did label the splice and reference the other diagram
Last edit: 8 years 1 week ago by Paul P.. Reason: I sit corrected!
The following user(s) said Thank You: Noah, Jrogers0229
8 years 1 week ago #23911 by Noah
Replied by Noah on topic Transmission Electeical
Seriously, a dotted line on the splice would have least you know there's more to see...
Thanks for coming though with those diagrams :)
  • Jrogers0229
8 years 1 week ago #23921 by Jrogers0229
Latest is I am only getting 3.8 volts on every 5v reference coming out of the pcm. Does this mean pcm is junk again? Or is there a sensor in the system throwing it off. If pcm is bad again what would make a pcm constantly go bad? They are too expensive to be replacing over and over.
  • Jrogers0229
8 years 1 week ago #23923 by Jrogers0229
Bad info. Forgot to put a fuse back in.
Still cannot get 12v from whit/ blu stripe wire from back of alternator. Should I have 12v coming from that wire? Stumped for sure.
8 years 1 week ago #23924 by Paul P.
Do you have any voltage with the KOEO at pin 25, Gray C3 at the ECM? There should be 12v.
  • Jrogers0229
8 years 1 week ago - 8 years 1 week ago #23932 by Jrogers0229
I will check that in the morning.
I see that is the wire I am confused about. Does that wire have power on it after the relay or does the relay require that wire to have power on it to work and then the pcm will see the 12v? Does the alternator need to see power on that wire to turn on and off? Today I was testing and I could not get any output out of the alternator, like it wasnt working. Just had everything tested last weekend. I think both the trans and the charging issue are connected just cant seem to solve it. Thx for the replies.
Last edit: 8 years 1 week ago by Jrogers0229. Reason: Add
8 years 1 week ago #23933 by Paul P.
That wire has 12v on it to the relay. The relay does require power on it to work. The PCM provides the ground path( the pink wire) to energize the relay. This is the 'Control' side of the relay.
Yes, it needs 12v from the PCM pin 25 connector 3. The PCM will use the other wire the Dark Green/White trace to 'energize' the alternator.
They most definitely are connected.
The transmission relay might be misleading you depending on how your doing your voltage checks.With the key on youll see 12 v at the relay for the WH/DB wire, but you may or may not see 12 volts on the pink, depending whether the PCM has provided a path to ground.
  • Jrogers0229
8 years 1 week ago #23956 by Jrogers0229
Ok so here's the delio....
I had to jump the pink wire coming from pin B 31.
The trans relay was not energizing. I was so focused on the white/ blue wire.
I had to put the white/blue wire into my wiring for the external regulator to excite the alternator.
What would make the pcm go out again? It's only a few months old.
Everything is working, maybe not the correct way but gets me started. Thanks to everybody that helped.
