P0621 dtc
- charless01
- cheryl hartkorn
- Thank you received: 130
The way I understand it, this code will set if the PCM sees high voltage on the L circuit (5V) KOEO, or low voltage KOER. The latter sound like your case.
Honestly, it sounds like the replacement alternator is suspect. Aside from rechecking voltage drops at the B+ cable and case ground at high RPM, and belt tension (possible slipping belt), I'd go with an OE alternator.
The only other test I can think of would be to disconnect the alternator and monitor the L terminal at high RPM. If it doesn't pull down, then the issue was in the alternator.
- charless01
- charless01
charless01 wrote: Thank you very much for your help. This dtc was set with the original alternator then the owner told me that he replaced it with a new one that fits perfectly but I don't know if it is a genuine chevy part. A will follow your advice and install another OE alternator. Voltage drop checks were done, test OK. In my opinion the failure is inside the pcm but I am not certain. Thanks again.
You might be right! :lol: I'm eager to see the result of this one, as I've never heard of an L-terminal problem like this one before.
I figured that raising the engine speed with the alternator disconnected might be a good test of the PCM, just to see if something is feeding back and causing a circuit issue. It's an open circuit check, though.
Thought about a belt slip problem because I've seen belts spin on pulleys and not make noise. :huh: The regulator in the alternator will pick up on this and try to ground the L-terminal.
- charless01
- charless01
