u0100 help with troubleshooting
  • chief eaglebear
  • chief eaglebear's Avatar
7 years 7 months ago #27993 by chief eaglebear
Replied by chief eaglebear on topic u0100 help with troubleshooting
this looks like a job for bob can bus fault finder lol
7 years 7 months ago #27994 by Dylan1214
Replied by Dylan1214 on topic u0100 help with troubleshooting
3 Gens wrote: Could you tell us the project you just finished?was everything in tact beforehand?were you able to log normally before?
Sure thing, So i installed a new cam, New heads, new intake manifold, A new fuel pump, new torque converter and a flex fuel sensor. I also uploaded a new tune via HP tuners.. And no i had 0 issues prior.
7 years 7 months ago #27995 by Dylan1214
chief eaglebear wrote: this looks like a job for bob can bus fault finder lol
Not quite sure what that is
  • chief eaglebear
7 years 7 months ago #27997 by chief eaglebear
Check out aes wave it is a Can bus fault Finder but wait till someone more experienced chimes in thanks
  • 3 Gens
  • 3 Gens's Avatar Topic Author
7 years 7 months ago #27999 by 3 Gens
Replied by 3 Gens on topic u0100 help with troubleshooting
when you installed the flex fuel sensor did you connect it correct?
www.camaro5.com/forums/showthread.php?t=497750
also there are many grounds that were attached to the motor did you return all of them in the same manner. these cars are vary finicky.
  • 3 Gens
7 years 7 months ago #28000 by 3 Gens
also your fuses for your fuel pump
The following user(s) said Thank You: Matts Auto
7 years 7 months ago #28025 by Dylan1214
3 Gens wrote: when you installed the flex fuel sensor did you connect it correct?
Yes, one of the few readings that are actually working on hp tuners is alcohol content so I know its hooked up properly.
And I have checked all fuel related fuses, (all fuses actually), I even swapped out my fpms relay. I've regrounded EVERY single possible ground.. im going crazy trying to figure this out..
  • 3 Gens
7 years 7 months ago #28032 by 3 Gens
7 years 7 months ago - 7 years 7 months ago #28034 by Tyler
Replied by Tyler on topic u0100 help with troubleshooting
Dylan1214 wrote: But i'm getting the codes and a loss of power steering, Also the majority of my readings (RPM etc) aren't pulling up or being read on HP tuners...
Are these symptoms constant or intermittent?
I check the voltage on my MAP sensor and its reading around 4.7 ish volts, BUT I just checked ohms between pins 6 and 14 and its ranging from -75 to -85 ohms (I'm guessing this is an issue?)
When was the HSLAN resistance reading taken, exactly? Abnormal readings like that may be normal if you took the reading with the engine running or the key on.
Also, which pin were you on when you measured MAP voltage? Engine off or running?
Again sorry for bringing up and old post but i've been throwing myself at this for over a week with no avail, I just wanna drive my finished project :/
No worries! In the future it'd probably be better to start a new thread so anyone else searching for fixes in the future will have an easier time finding it. But for now, let's fix your project. :cheer:
Last edit: 7 years 7 months ago by Tyler.
7 years 7 months ago - 7 years 7 months ago #28094 by Dylan1214
So I get that reading (-750 - -850 ) when I check right after opening my door with motor off and key out, However I check again a couple mins later with door still open, key and motor off and it reads 002
And I checked the first pin of my map sensor which currently reads 4.93 volts
Last edit: 7 years 7 months ago by Dylan1214.
7 years 7 months ago #28100 by Tyler
Dylan1214 wrote: So I get that reading (-750 - -850 ) when I check right after opening my door with motor off and key out, However I check again a couple mins later with door still open, key and motor off and it reads 002
Interesting. B) Is the ECM easily accessible? If so, leave your DMM connected across pins 6 and 14, and unplug all three connectors. Key out, door closed, wait a couple minutes and recheck the meter. Hopefully, it'll be close to 120 ohms.
7 years 6 months ago #28184 by Dylan1214
UPDATE: I re uploaded a new tune hoping the old one had an issue.. I no longer have the u0100 code, Now i have P069E (Fuel Pump Control Module Requested MIL Illumination (SES, Pending, Current, History) and P0603 - Internal Control Module Keep Alive Memory (KAM) Error (Pending, Current)
At this point i'm thinking it has to be a bad pcm or fpcm
7 years 6 months ago #28187 by Dylan1214
It only has 2 harness leading into it (E-38 ECM) but its reading 004 ohm
7 years 6 months ago #28271 by Tyler
Dylan1214 wrote: It only has 2 harness leading into it (E-38 ECM) but its reading 004 ohm
Really? :blink: I need to be clear about this. You're connected across pins 6 and 14 at the DLC, with the key off and doors shut after a couple minutes?
If so, the CAN lines are still shorted to each other. Even if you have a PCM problem, replacing it won't fix this condition. :silly:
7 years 6 months ago #28363 by Dylan1214
Yes this is the case.
7 years 6 months ago #28396 by Dtnel
Replied by Dtnel on topic Re:u0100 help with troubleshooting
Tyler I learned something new a few weeks ago when looking into a Bosch ADS625 purchase. The battery voltage reading. IF you're taking a scan reading from the OBD II port and have less than 12volts you can get erroneous network and other codes.
Would it be possible in this situation? The only reason I ask is I haven't seen it brought up. Also in this thread from the OP and the 2nd post added in when speaking of taking measurements from the mentioned pin numbers on the port is it those pin #'s counting from the right or left.
You do this stuff probably blindfolded but I'm still learning the small details so my brain needs to be massaged with this info
Been a good read so far and how it's showing that heat is a enemy on these vehicles. To much stuff packed in such a small compartment. My 04 Tahoe hasn't had these brittle wire / heat related issues yet, knock on wood. I'll run it until the body is like a Flintstones car just for the simple fact I get free oil changes as long as I own the vehicle. Only 124k miles on it so far.
If we have to change the engine later we can do that and still keep getting the free oil changes.
Sent from my SM-N960U using Tapatalk
7 years 6 months ago #28399 by Tyler
Replied by Tyler on topic Re:u0100 help with troubleshooting
Dtnel wrote: Tyler I learned something new a few weeks ago when looking into a Bosch ADS625 purchase. The battery voltage reading. IF you're taking a scan reading from the OBD II port and have less than 12volts you can get erroneous network and other codes.
Definitely possible! But in my experience, the battery voltage needs to be lower than that to cause network issues. Less than 11, closer to 10 usually. If the OP wanted to rule this out, we could have him attach a charger or jumper pack? But, with all the accessories piled on newer cars, I figure the battery voltage will almost always go below 12V KOEO. :silly:
It's not necessarily right or left, but just facing the connector itself. I usually remember by finding pins four and five, middle of the 'fat' half of the connector. :lol: 16 is always at the skinny end of the other half. From there, I count out the pins I want.
Nah, not blindfolded. :silly: I actually use the scope far more often for network stuff, but I'm trying to get more comfy with the DVOM for this type of testing, because that's what our members usually have available to them.
Weird. :blink: I can't figure why this network would be shorted together after your repairs. Is the ABS module accessible? That's the next module on that leg of the the HSLAN that's not dependent on vehicle options. Disconnect it and recheck your reading at the DLC.
  • 3 Gens
7 years 6 months ago #28813 by 3 Gens
Replied by 3 Gens on topic Re:u0100 help with troubleshooting
Any luck yet?
7 years 4 months ago #30612 by Dtnel
DID this thread just die? Was going thru old threads and saw I hadn't read it in awhile but also no updates or even a confirmed fix either. Weird but maybe not as people get caught up in life and it's that nice time of year.
7 years 4 months ago #30692 by Tyler
Dtnel wrote: DID this thread just die? Was going thru old threads and saw I hadn't read it in awhile but also no updates or even a confirmed fix either. Weird but maybe not as people get caught up in life and it's that nice time of year.
I'd be happy to hear back on this one, but I definitely understand that people get busy. :)
Off topic, are you still happy with your ADS 625? I'm real close to pulling the trigger on one. Mostly looking for some real world experience in an Indy shop, or maybe get my hands on one for a couple days to test it out.
Time to create page: 0.469 seconds
