P0017 STALLING AT IDLE ONLY WHEN ENGINE GETS WARM
8 years 3 weeks ago #23542 by FIX
I HAVE A 2005 GMC CANYON WITH A 2.8 ENGINE
IT STALL AFTER IT GET WARM AND ONLY AT IDLE IT RUNS GOOD WITH NO OTHER PROBLEM
IT HAS A NEW ECM/CAM PHAZER/T-BODY AND CUSTOMER SAY THE TIMING CHAIN HAS BIN REPLACE
I AM THE 4 SHOP TO LOOK AT IT AND HE IS A NEW CUSTOMER
I WOULD LIKE TO CHECK TO SEE IF IT IS OUT OF TIME BUT CANT FIND ANY WAVE FORMS FOR THIS TRUCK
SOME TIME I GET A P0300
I HAVE SCOPE ALL SENSOR AND CANT FINE ANY THING WRONG
I THING IT HAS A TIMING PROBLEM BUT I CANT VERIFY IT
IF ANY ONE NEEDS MORE INFO JUST LET ME KNOW
  • chief eaglebear
  • chief eaglebear's Avatar
8 years 3 weeks ago #23554 by chief eaglebear
Replied by chief eaglebear on topic P0017 STALLING AT IDLE ONLY WHEN ENGINE GETS WARM
why am I thinking egr it seems like I am hooked on egr and iat symptoms but can never diagnose them correctly maybe scope your thermal switch see if its opening when its supposed to and as far as timing goes I think you can do what we call a duel trace scope the cam and the crank for comparisons off of an ignition sync I am kind of a novice still some input from noah ben or graywave will help huaahhh good luck
8 years 3 weeks ago #23561 by Ben
P0017 is cam to crank timing correlation get a capture of the cam to crank waveform and I'll see if I or someone else on here can find a known good to compare to
8 years 3 weeks ago #23582 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic P0017 STALLING AT IDLE ONLY WHEN ENGINE GETS WARM
Is it cutting instantly dead or stumbling first?
How easy is it to restart ? or will it only re-start after a cool down?
How long after a cold start is it cutting out ? is it in open or closed loop ?
I
  • TheTechWhisperer
  • TheTechWhisperer's Avatar
8 years 3 weeks ago #23591 by TheTechWhisperer
Replied by TheTechWhisperer on topic P0017 STALLING AT IDLE ONLY WHEN ENGINE GETS WARM
How about your oil pressure? If it gets better above idle, and is ok at cold start (when it is in open loop and off-idle), I would check the simple things first. Oil pressure, level, condition, etc.
"You will always find the greatest fulfillment in life when you are operating in the gifts God gave you"- Dad
National Director of Technical Training & Mechanical Operations - Express Oil Change & Tire Engineers
ASE Master L1 Tech
BMW Master Tech
Ford FACT Advanced Electronics Instructor
8 years 2 weeks ago #23674 by Paul P.
Do you have a pressure transducer for your scope?
Never stop Learning.
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
8 years 2 weeks ago #23681 by cheryl hartkorn
Replied by cheryl hartkorn on topic P0017 STALLING AT IDLE ONLY WHEN ENGINE GETS WARM
are you in dayton ohio roughly? i heard a mobile guy john talking about which seems like this truck
