Misfire
  • Jreed588
  • Jreed588's Avatar Topic Author
8 years 3 weeks ago #23530 by Jreed588
Misfire was created by Jreed588
I have a 2001 Jeep Grand Cherokee 4.0L 4x4 with a miss fire. I have replaced the spark plugs twice I have put a new cam position sensor and coil pack I also have replaced 3 of the 6 fuel injectors. Since do all that I still have a mis but no check engine light HELP ME PLEASE!!!!!!??????
8 years 3 weeks ago #23532 by Tyler
Replied by Tyler on topic Misfire
When does the misfire occur? Idle, cruise, under load?
Second, do you have an idea of which cylinder is suspect? If not, a power balance test is in order. Once we know which cylinder is weak, and when, we can narrow down the suspects.
  • Jreed588
8 years 3 weeks ago #23558 by Jreed588
Replied by Jreed588 on topic Misfire
It happens at idle under load at cruise all cylinder but one or two cylinder are kicking codes plus it's kicking codes for coil pack I think part of the issue is the crank sensor I put in is bad but it had a constant mis fire in at least one cylinder and would not kick a code
8 years 3 weeks ago #23559 by Ben
Replied by Ben on topic Re:Misfire
Do you have access to a scope? Improper crank sensor air gap can cause the sensor to miss windows was it cam sensor or crank sensor that was replaced?
Time to create page: 0.389 seconds
