Odd spark lines
- 111Robin
8 years 1 month ago #23459
by 111Robin
Odd spark lines was created by 111Robin
This is from a 4 cylinder engine from a 1967 Mini Cooper running all original points ignition. The scope is on a 1979 Sun 1115 Performance Analyser. The engine is running perfectly, no misfiring, the only indication of a problem is from the secondary pattern. On three of the four cylinders the spark line isn't a clean vertical line but has strange loops and anomalies. HT leads and plugs are new but the cap is possibly thirty years old. Engine seems to perform well, no missing or other indications of an ignition fault. Any suggestions ?.
VideoCapture_20180922-191433
by
Robin Derrick
, on Flickr
- 111Robin
8 years 1 month ago #23460
by 111Robin
Replied by 111Robin on topic Odd spark lines
- 111Robin
8 years 1 month ago #23461
by 111Robin
- 111Robin
8 years 1 month ago #23462
by 111Robin
Obviously I can just replace the cap however before doing this I'd like to be able to diagnose the possible causes of the odd patterns.
- 111Robin
8 years 1 month ago - 8 years 1 month ago #23463
by 111Robin
Last edit: 8 years 1 month ago by 111Robin.
8 years 4 weeks ago #23469
Replied by Andy.MacFadyen on topic Odd spark lines
Looks like a scope artifact, a scope trace can't loop in normal volts against time mode.
Time to create page: 0.371 seconds
