Need help with trouble code
  • trent38
  • trent38's Avatar Topic Author
8 years 2 months ago #22670 by trent38
Need help with trouble code was created by trent38
vehicle is 2000 ford explorer 4.0 sohc.
Guys i keep getting a lean code po171 on my explorer. The fuel trim levels are between 17-19 but on both banks. The short term change but stay between -10 to + 10. I have changed plug and wires. Checked for vacuum leaks. The upper intake gaskets were replaced 6 months ago and fuel filter. Lower intake hasnt been replaced. I just dont know where to go from here any help is appreciated.
8 years 2 months ago #22679 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Need help with trouble code
An air intake leak anywhere between the MAF and the engine could be the sources of your trouble or a bad/dirty MAF. One other thing that can cause similar issues are any changes to the air intake. MAF's are carefully calibrated to the intake drsign any changes such as removing the mesh screen or fitting a cold air intake can cause a lean condition
8 years 2 months ago #22681 by derekoliveira
Replied by derekoliveira on topic Need help with trouble code
What kind of conditions do you have does values, only at idle or open throttle to?
  • trent38
8 years 2 months ago #22683 by trent38
Replied by trent38 on topic Need help with trouble code
Its all the time. Cold start is high and higher rpms the same
  • trent38
8 years 2 months ago #22684 by trent38
its all stock
8 years 2 months ago #22699 by derekoliveira
Like Andy say, check MAF and clean it! And review data pids. If it does not work try fuel pressure!?
Time to create page: 0.372 seconds
