2001 f150. 5.4. Wont start in the morning or let it off for acouple hrs.
- gerber
- Thank you received: 4
No codes.. no check engine light on. If i put little gas on the intake. .start right away.snd run with no problem..
New fuel pump. (Pressure 40 psi) new fuel filter.. air.filter.. i used good iac..new iat.. i cleaned the maf sensor. New sparkplugs.. any advice
Thanks..
- Ben
- Thank you received: 215
- gerber
- Ben
- gerber
- gerber
gerber wrote: If i put some carburator choke after maf sensor wont start too.. but if i do before the maf start right away
Are you saying that if you spray Carburetor Cleaner into the intake BEFORE the MAF, drawing the carb cleaner THROUGH the MAF, it will start?
But, spraying in AFTER the MAF, it won't start?
Like this?:
- gerber
- gerber
When cranking and no-start, do you have injector pulse?
- gerber
- BowtieGuy18
- gerber
- Ben
