P0054 only on every other morning cold start
- broekstra
8 years 3 months ago #22181
by broekstra
P0054 only on every other morning cold start was created by broekstra
2008 Buick La Crosse, 3.8L V6. 107000 miles.
Originally my CAT and resonator went bad so I replaced the entire exhaust system along with a new o2 sensor, sensor 2. Since the entire replacement of the exhaust system was done two weeks ago the code P0054 comes up on a morning cold start, ONLY EVERY OTHER MORNINGS! When the P0054 comes on in the morning I clear it and it won't come back on until the second cold start( two mornings or 48 hours from the time of clearing the code). This happens consistantly, P0045 every other morning.
I had a garage check the o2 wires and connection and was told the wire loom on each side of the connector looked good, not against exhaust pipe, broken wire , etc.
BTW, I read something about clearing the codes before installing new o2 sensors. The code for the CAT may have not been cleared before the replacement of the exhaust system. Could this be a contributing factor? Also the weather temp. has been consistant the few weeks, no extreme climate changes.
I'm having a hard time understanding how a possibly bad o2 sensor can cause a P0054 only ON EVERY OTHER MORNING. I am going to check the heater resistance of the o2 sensor? Should the resistance be about 5 or 6 ohms? If the resistance is good what could be causing this every other morning P0054 code? PCM?
More info: Yesterday was the morning the code was to come up again, but the night before I pulled off the positive cable of the battery for a few minutes and reconnected it. So by removing power, the code P0054 did not come on yesterday morning but it did come up this morning so the problem is still there. Don't know if that helpful or not.
Has anyone seen this before? Please help!
Ben
Ben
- bruce.oliver
- Thank you received: 88
8 years 3 months ago - 8 years 3 months ago #22195
by bruce.oliver
Replied by bruce.oliver on topic P0054 only on every other morning cold start
That is a heater resistance code. The PCM may only check the resistance at a cold start and it is likely a 2 trip fault. So you clear the code and it takes 2 cold starts to set the code again. Check the heater resistance.
Conditions for Running the DTC
P0054
The ignition is OFF for more than 10 hours.
The engine coolant temperature (ECT) Sensor parameter is between -30 and +45°C (-22 and +133°F) at engine start-up.
The difference between the start-up ECT and the intake air temperature is less than 8°C (14.4°F).
The system voltage is between 10–18 volts.
This diagnostic runs one time per valid cold start when the above conditions are met.
Conditions for Setting the DTC
P0054
The PCM detects that the HO2S heater calculated resistance is not between 21.2–8.8 ohms at engine start-up for 1 second.
P0054
P0054
Last edit: 8 years 3 months ago by bruce.oliver.
- broekstra
8 years 3 months ago #22206
by broekstra
Replied by broekstra on topic P0054 only on every other morning cold start
Thanks Bruce. Your response has filled some holes for me. I'll go check the resistance of the o2 sensor.
Thanks again,
Ben
Thanks again,
Ben
Time to create page: 0.267 seconds
