help 2011 Toyota Tacoma 2.7L cylinder 1 misfire after replacing knock sensor.
- Johnaldregan
I'm wondering if the fact that the misfires stop counting with the knock sensor disconnected may be misleading. It could be that the misfire is still occurring, but the ECM stops counting misfires as part of a fail-safe strategy once a knock sensor code sets as Current.
Knock sensors normally aren't polarity sensitive, so I really doubt that you damaged anything with reversing the wires.
With the knock sensor connected and fault codes cleared, what are your fuel trims at idle and 2,500 RPM?
Since you've already done an audible relative compression test and replaced some other parts, I'm thinking you may have an intake leak on cylinder #1 and/or #3. I'd be tempted to do the good ol' SD water test on the intake and see if you can hear a leak:
- Johnaldregan
- Johnaldregan
- Johnaldregan
- Johnaldregan
- Johnaldregan
- Johnaldregan
At idle 935rpm
Short fuel trim 0.781 to 1.56
Long fuel trim 30.46
At 2505 rpm
Short trim 0.781 to 1.56
Long trim 16.40
- Johnaldregan
Manifold gasket and found that out because istill had the issue. used a straw to focus a little water directly into the insulator area. worked pefectly. So now working on replacing the lower fuel injector insulator on #1 cylinder. since the (fuel injector) upper o-ring is new and the lower o-ring cushion is also new. Also I now got have a code p0010 for the bank 1 vvt solenoid. I tested voltage with car on but not running. And only see .57 volts I watched another video testing that connector for the vvt solenoid and they had upwards of 8 volts. Could this be an issue also?
- Johnaldregan
So the leak ended up being the injector one cylinder. I replaced the intake
Manifold gasket and still had the issue. So working on replacing the lower fuel injector seal now. since the (fuel injector) upper o-ring is new and the lower o-ring cushion is also new. But the lowest one that the cushion sits on wasn’t replaced and that’s where it is sucking\leaking from.
Awesome! Great find. I've had troubles with the lower injector seals on Toyota products before, as well. A vacuum leak at the injector seal would very neatly explain the misfire on cylinder #1 and the fuel trim values you posted.
No offense meant, but are you sure the VVT solenoid connector wasn't left unplugged at some point during your testing/repairs? I can't recall ever having problems with the 2.7L VVT systems.Also I got code p0010 for the bank 1 vvt solenoid. I tested voltage with car on but not running. And only see .57 volts I watched another video testing that connector for the vvt solenoid and they had upwards of 8 volts. Could this be an issue also
The VVT solenoid on this engine is power side switched, meaning that you'll only see power at the solenoid with the engine running and the solenoid commanded on. Toyota service info indicates that it'll be a 12V pulse width voltage.
I had tested the vvt solenoid also and the actuator for the solenoid is working peoperly moving up and down. But the ohms reading was 7.6 and I saw somewhere it said it should be 8 ohms or above. Does my vvt solenoid sound ok or needs to be replaced also ?
Solenoid resistance can change depending on temperature, so 7.6 ohms is close enough for me. I'd leave the solenoid alone for now and check the circuit.
- Johnaldregan
- Johnaldregan
- Johnaldregan
