A/C Switch disables 1 O2 sensor readings, Head scratcher
  • craigc
  • craigc's Avatar Topic Author
8 years 3 months ago #21988 by craigc
2002 Nissan Xterra with V6 VG33E.
All 4 new Bosch O2 sensors, I monitor B1 and B2 sensors and when the A/C switch is off there is no response for B1 O2S1 but when I turn on the A/C switch it starts to respond. I even unplugged the A/C compressor but cycling just the switch still causes the weird problem.
I've attached a PDF of the engine wiring diagram.
I'll try and take a video of the problem to aid in diagnosing.
Thanks in advance
8 years 3 months ago #21996 by Chad
Have you back-probed the sensor connector to see what your voltages are doing when switching the A/C on and off?
The following user(s) said Thank You: craigc
  • craigc
8 years 3 months ago #21997 by craigc
Actualy today I did backprobe the signal wire with my fluke meter on min/max and it seems the B1 upstream sensor basicalt flatlines after a min or two of switching correctly. I also backprobed the O2 heater circuit and after start it went from battery voltage to about 300 mV so it seems the heater is working.
Thanks again
8 years 3 months ago - 8 years 3 months ago #22012 by Chad
craigc wrote: Actualy today I did backprobe the signal wire with my fluke meter on min/max and it seems the B1 upstream sensor basicalt flatlines after a min or two of switching correctly.
At what voltage does it flatline? Is the flatline due to the Min/Max limits finally maxing out? What happens if you turn min/max off?
^^^Hopefully, someone else will chime in on this. This doesn't sound right, to me. 300mv seems a bit high for the ground circuit.^^^
I pulled this from all data:
Last edit: 8 years 3 months ago by Chad.
8 years 3 months ago #22015 by Tyler
pole71 wrote: ^^^Hopefully, someone else will chime in on this. This doesn't sound right, to me. 300mv seems a bit high for the ground circuit.^^^[/attachment]
I guess I'm OK with this as long as it's a pulse width modulated heater? :huh: Otherwise that does seem a bit high. Still, I'm not sure a heater circuit fault on an upstream sensor will cause this.
Any fault codes? What are the fuel trims doing when the switch is on and off?
