2008 Tahoe 5.3 Rough Idle
  • anahirnyj
  • anahirnyj's Avatar Topic Author
8 years 3 months ago #21739 by anahirnyj
2008 Tahoe 5.3 Rough Idle was created by anahirnyj
I have 2008 Chevy Tahoe with the 5.3 flex. It as about 175,000 miles on it.
The problem that i'm having is rough idle. It starts fine, doesn't stall, seems to run fine at higher RPM.
Some additional info:
- no codes
- new plugs and wires (I know... probably didn't need them)
- Checked the resistance of each fuel injector and they were good - also I could hear each injector pulse with a dr. type scope.
- Fuel trims look good:
-- STFT Bank 1 = 0,
-- LTFT Bank 1 = 0,
-- STFT Bank 2 = -2,
-- LTFT Bank 2 = -3.1
There are no missfires
Fuel pressure (according to scan data) is 43.5psi running (spec is 50-60)
Mass Airflow Sensor = 0.01 lb/s
Throttle Position = 19.2%
I am:
- considering cleaning the throttle body.
- concerned about the fuel pressure (but need to do more research)
- wondering if it could be a mechanical issue and that I should do a compression check.
Thoughts?
8 years 3 months ago - 8 years 3 months ago #21743 by Ninjaxchicken
Replied by Ninjaxchicken on topic 2008 Tahoe 5.3 Rough Idle
Umm that lbs/min is low on ur maf.... it should be reading .7 lb/min or approx 5grams/sec since u have a 5 liter engine... this .01 lb/min is way low.... clean the mass air flow sensor and check power and ground to the sensor... also this 19% on the tps is that idle foot of the pedal??? If it is thats too high in my opinion
Last edit: 8 years 3 months ago by Ninjaxchicken.
  • anahirnyj
8 years 3 months ago #21744 by anahirnyj
Replied by anahirnyj on topic 2008 Tahoe 5.3 Rough Idle
My maf reading was in lb/s not lb/min so if converted to lb/min it equals = 0.6 or 4.5 g/s which still is lower than .7 but not as far off.
The tps reading was at idle, so I think i'm going to look at that some more.
Thanks
8 years 3 months ago #21759 by Ninjaxchicken
Ok your right im sorry i didnt catch the s... i thought i saw an m
8 years 3 months ago #21760 by Ben
Replied by Ben on topic Re:2008 Tahoe 5.3 Rough Idle
That is still a little low on the maf ,and tps is way high clean the maf and the throttle body
8 years 3 months ago #21765 by Tyler
Replied by Tyler on topic Re:2008 Tahoe 5.3 Rough Idle
Was that Throttle Position reading Relative of Absolute?
I agree, the 4.5 g/s reading is too low for this engine at idle. I'd suspect a vacuum leak, but the trims are excellent. :blink: Whats the MAP reading during the rough idle and 4.5 g/s MAF reading?
