Short or bad ground problem
- Rotatingrotar89
Okay so I am working on A 2004 audi a4 convertible w/ a 3.0 v6. Problem is I caused a short. Had the entire top end of the engine torn apart for a valve job. Then put it all back together only I made a huge mistake!! it's European and I'm use to working on domestic and jdm cars.... Well I accidently plugged a hot wire going from the starter to the alternator into a block ground. That wire should have been plugged to the alternator but I hot confused as blk can also be ground on the cars. Well any way the car started after realizing my mess up. Only started twice though and on the second time it shut off and just cranks sometimes it won't crank though.
It has no codes through regular obd2 only has codes using obd11 scan tool. The main one I saw was low voltage to ecu and the fuel pump doesn't sound.
I also noticed with a test light after unplugging negative terminal from batt...batt post[neg] to any ground on the car gets voltage it lights up....
The second I put the test light on the negative terminal of the vehicle and plug it to the negative battery post the light goes away
Some other strange things I noticed when I unplugged the vehicle computer and set my test light to ground when touching the wht/blk wire on the computer harness I would get the ecu relay to activate with the key out of the ignition. Also noticed when I activated the relay I checked the voltage only had 3.52 volts with a voltage drop of 8.89volts
I have plenty of schematics if someone with more knowledge is willing to help me out and teach me something or point out what I'm missing been working on this self caused electrical issue for a month now this is where I'm at
There's a ton of different direction you could go with this, and I'm hopeful others chime in with their thoughts. For me, I'd chase that battery > starter > alternator circuit and the intermittent no crank first. A voltage drop from the B+ post (not the cable end) to the alternator B+ post would be a good place to start. When the engine is a no crank would be best. If you find excessive drop, work your way closer to the battery until you start getting good readings.
A quick voltage drop across that main 150A fuse would be a good idea, too.
pole71 wrote: Do you have a ground distribution diagram? I think you have burnt 1, or more, grounds. You must have put the battery cable on very quickly, and completely, to avoid being showered with sparks instantly. Since you mentioned no sparks, I can only assume that smaller ground wires were burnt and acted as fuses.
pole71 wrote:
Rotatingrotar89 wrote: I also noticed with a test light after unplugging negative terminal from batt...batt post[neg] to any ground on the car gets voltage it lights up....
That is to be expected, if there is something using the BAT + , (such as a dome light, radio, various modules, etc).
Every thing needs power and ground to work. When you disconnected the negative battery cable, somewhere, a light went out, a module powered down, etc. That/those components are still looking for a ground. When you connect a test light to battery negative, and then touch the engine block, you completed the circuit and gave those components the path to ground they were waiting for. Because the test light it is, essentially, a resistor, the components do not get a GOOD ground and will not work. But, the current flow is still there. That is why the test light illuminates. Or, this could be a shorted component finding ground.
- Rotatingrotar89
I recently used a meter and found (17) shorts in total:( 7 )in various relays one of those being the ecu relay that I swapped. (9) in my fuse box three of which are ecu related. and (1) in my ignition switch
The short is only present in the ignition when it is switched to the off position, yet when turned to the on position it becomes an open
Please give me some advice otherwise I might just have to lose more money at the dealership
