Buick enclave 2009 fuel trim
  • Acosta
  • Acosta's Avatar Topic Author
1 year 7 months ago #83508 by Acosta
Buick enclave 2009 fuel trim was created by Acosta
Hello people it is a normal when I have the short fuel trim and the long fuel trim at 0% they don’t move are always in 0% y tried increase the rpm , no changes thanks
1 year 7 months ago #83509 by ferris48
Replied by ferris48 on topic Buick enclave 2009 fuel trim
check front o2 sensors if they're oscillating 0-1V range usually means it's in fuel control and check loop status.
The following user(s) said Thank You: Acosta
  • Acosta
1 year 7 months ago #83510 by Acosta
Replied by Acosta on topic Buick enclave 2009 fuel trim
They are in 4.5 v and 4.4 v
1 year 7 months ago #83513 by ferris48
are you looking at the Module Signal PID by any chance?
  • Acosta
1 year 7 months ago #83521 by Acosta
I mean I have these codes : P0135 , P0155 , P0031 , P0051 ,
P0030 and P0050 . I’m not sure if my O2 sensors are lying or I have another problem. Thanks
1 year 7 months ago #83593 by ferris48
DTC P0030:  HO2S Heater Control Circuit Bank 1 Sensor 1
DTC P0031:  HO2S Heater Control Circuit Low Voltage Bank 1 Sensor 1
DTC P0050:  HO2S Heater Control Circuit Bank 2 Sensor 1
DTC P0051:  HO2S Heater Control Circuit Low Voltage Bank 2 Sensor 1
The ECM detects an open in the heater circuits of the HO2S when the heater is commanded OFF. The condition exists for greater than 4 seconds or a cumulative of 30 seconds.
The ECM detects a short to ground in the heater circuits of the HO2S when the heater is commanded OFF. The condition exists for greater than 4 seconds or a cumulative of 30 seconds.
Check the EMISSION 1 fuse. If it's blown, check for a short to ground.
  • Acosta
1 year 7 months ago #83601 by Acosta
Ok thanks very much bro
