2003 Toyota Camry V6 A/C
  • ShrimplyPibbs
  • ShrimplyPibbs's Avatar Topic Author
8 years 4 months ago #21343 by ShrimplyPibbs
2003 Toyota Camry V6 A/C was created by ShrimplyPibbs
I have a 2003 Toyota Camry V6 and the AC light is flashing when I turn it on. Clutch relay has already been replaced following the procedure in the TSB. The odd thing that happens is when I first get in the car and try to turn the AC on the light flashes but after the engine has been running for a few minutes the AC turns on and works perfectly. Any tips on where I should take my diagnosis from here would be greatly appreciated. Thanks in advance!
8 years 4 months ago - 8 years 4 months ago #21347 by Tyler
Replied by Tyler on topic 2003 Toyota Camry V6 A/C
I think I'd start by monitoring voltage on the compressor clutch power feed during those first few minutes after startup when the clutch isn't engaging. The compressor is down low on the 3.0L, so you may need to find that same wire further up the harness and tap in for testing purposes. If you've got 12V, or a test light that shines brightly when connected to B-, then you know the wiring is good up until that point.
With 12V to the clutch and no engagement, you're likely looking at a bad clutch field coil or a clutch with excessive air gap. Either one will cause the A/C lock sensor to produce no signal and report to the ECM that the compressor isn't spinning.
Now, if the clutch actually engages during those first few minutes and shuts right off again, then that'd suggest a problem with the lock sensor itself. That's a different test, so let us know what you're seeing and we can go from there.
For anyone else following along, there's an excellent Premium series on this Toyota/Lexus lock sensor system. Check it out:
www.scannerdanner.com/scannerdanner-prem...dGEiLCJ0b3lvdGEncyJd
Last edit: 8 years 4 months ago by Tyler.
  • ShrimplyPibbs
8 years 4 months ago #21385 by ShrimplyPibbs
Replied by ShrimplyPibbs on topic 2003 Toyota Camry V6 A/C
Thank you for the info! I’ll post what I find after I perform the test this weekend.
8 years 4 months ago #21405 by Chad
Replied by Chad on topic 2003 Toyota Camry V6 A/C
