2007 hhr 2.2 liter charging system question
- cheryl hartkorn
- Thank you received: 130
8 years 4 months ago #21291
by cheryl hartkorn
2007 hhr 2.2 liter charging system question was created by cheryl hartkorn
does anybody remember what voltage you are supposed to see on the generator turn on signal wire unplugged engine running?? i have a no charge issue but havent messed with these in awhile... for some reason i want to say its supposed to be 5 volts. im getting just a few 100 millivolts.
8 years 4 months ago - 8 years 4 months ago #21294
Replied by Chad on topic 2007 hhr 2.2 liter charging system question
Last edit: 8 years 4 months ago by Chad.
8 years 4 months ago - 8 years 4 months ago #21312
Replied by Andy.MacFadyen on topic 2007 hhr 2.2 liter charging system question
Multimeter with a Duty Cycle scale should be enough tell you if the engine computer is signalling the alternator to produce more current.
If your meter lacks a duty cycle scale with engine running on the L terminal with a decent battery on the battery when with everything working well using a DC voltage scale expect to see 50 to 60% of battery voltage. If battery voltage is low or alternator is not working expect to see close to battery voltage.
Last edit: 8 years 4 months ago by Andy.MacFadyen.
- cheryl hartkorn
8 years 4 months ago #21317
by cheryl hartkorn
Replied by cheryl hartkorn on topic 2007 hhr 2.2 liter charging system question
well followed the flow chart i found it says key on engine off connector unplugged from alternator should be 0 volts. then start the engine should be near 5 volts on the l terminal. my friend will be putting an alternator on. we did find a broken wire it read what it was supposed to at the pcm but not at the alternator. thought it was fixed but it wasnt.
