Eobd
  • Fox.b
  • Fox.b's Avatar Topic Author
8 years 5 months ago #20847 by Fox.b
Eobd was created by Fox.b
I was wondering if any of you guys have seen this "problem".
I plugged into a Vauxhall Astra vxr and it had no EOBD codes, but in manufacturer specific it had 5 engine codes. Problem is that in manufacturer specific there is no freeze frame.
Havre thou guys seen no EOBD codes but in maker side there are?
8 years 5 months ago #20870 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Eobd
EOBD like OBD2 and JOBD keeps to a core number of codes related to only codes that could cause an increase in emmisions. EOBD/JOBD/OBD2 codes have to be tested when the manufacturer certifies a vehicle and engine type meets emmisions standards as a result these codes and PIDs tend to be reliable than manufacturers extended ones and spurious manufacturers fault codes are not unkown for example some Land-Rover Freelanders throw up a code for an oil temperature sensor fault when none is fitted.
The following user(s) said Thank You: Fox.b
