Conditions for Closed Loop
- paulsomlo
- Thank you received: 1139
If the downstream 02 were disconnected all together I imagine it could effect loop status, or if it was sending a signal so erronious that the pcm could no longer maintain fuel control it might default to open loop, or open loop fault.
Considering the variables, I'm not 100% sure it's possible, but I don't think it would be norm.
- paulsomlo
What I'm really after, is whether the upstream sensor has failed, or is the loop just not closing. I don't have the experience to know what voltage to expect from the upstream sensor under open loop conditions assuming a good sensor.
By the way, the cooling fans come on periodically, and the temp gauge on the dash reads normally - can I safely assume that the ECM is interpreting this as "fully warmed"?
The upstream O2 sensor signal is unusual.
- paulsomlo
Another data point - I disconnected the upstream sensor, took a spin around the block, no difference in performance. Truthfully, I'm not even certain as to whether it's a narrow band or wide band sensor.
Depending on which wire you were probing, that 300mV reading you saw may be entirely normal. It sounds like you were on the sensor signal wire based on your description. :huh: I'm not super familiar with Subaru A/F sensors. Where was your scope ground connected?
At this point, I think you'll need scan data to make a definitive call on your P0420.
- juergen.scholl
- Active partschanger
- Thank you received: 462
Andy.MacFadyen wrote: . Normal upstream narrowband voltages vary between car and sensor manufacturer and normall a low voltage is returned for a rich condition and higher voltage for lean.
Now that you're confusing me....You didn't happen to mean WIDEBAND voltages in the quoted phrase, did you?
juergen.scholl wrote: Now that you're confusing me....You didn't happen to mean WIDEBAND voltages in the quoted phrase, did you?
:lol: I think you're right. Give him a break, he's on vacation.
Now back on topic ISTR Matt on Schrödingers Box YouTube channel has a video on known good Scooby Wideband sensor.
paulsomlo wrote: 2003 Subaru Outback, 2.5L
Most cars drive fine with the upstream disconnected they will use a default slightly rich fuel map without closed loop. It might be an issue if you had the car at a high altitude such as Mexico city or Colorado or in exceptional high ambient temperatures. Back before electronic fuel injection all gasoline engines ran very rich by modern standards, so rich that engine life was much shortened by bore washing. Within reason a fuel air mixture that is over rich will produce loads of power at the expense of a lot of pollution.
- juergen.scholl
Are there still some Vespa scooters from the 60s or 70s around? Boy, they ran rich as well, but on 2 stroke oil (anywhere from 1:50 to1:25).
- paulsomlo
I used an all purpose digital storage scope and probed the two signal wires (white and blue) taking one of them as ground. I tried it again last night with a DVM, same result, 300mV between the two signal wires. I did measure each signal wire to ground; 1.9V and 2.19 V, using the intake manifold as my ground. The difference voltage across the two signal wires did change when disconnecting a vacuum line from the intake manifold, increasing, then settling back to 300mV with the vacuum line still disconnected.
My previous "driveway" test showed the downstream sensor sitting steady, no switching.
I think you're right - I'm at the point where I need to see scan data. As a DIY'er, I don't have a scan tool. I was thinking maybe a bluetooth dongle and the torque pro app?
PS - I did look at that video, Andy. The voltage displayed on the phone app is right around 2.1V
A Bluetooth dongle and an app would be just fine for this. There's a huge selection out there - I have this one from Amazon, works perfectly:
www.amazon.com/BAFX-Products-Bluetooth-D...canner/dp/B005NLQAHS
FWIW, I can't stand Torque.
