03 Lancer DTC Codes
- Darkendrain
8 years 5 months ago #20799
by Darkendrain
03 Lancer DTC Codes was created by Darkendrain
So I’m looking into buying this guys 03 lancer oz rally edition but he ran diagnostics and two codes came back P0421 and P0302. I know the first is cat below threshold and the second is cylinder 2 misfiring. What I want to know is when I go to take a look at the car, what should I be checking to make sure I’m not buying a car that’s going to cost me more money than it’s worth? Or can you already tell it’s not worth it just by those codes. Any other suggestions would be appreciated too. Thanks!
- Dave101
- Show me what it's not!!
- Thank you received: 7
8 years 5 months ago #20801
by Dave101
Replied by Dave101 on topic 03 Lancer DTC Codes
I would check the ignition that the cylinder is missing. You probably have an ignition problem causing fuel to be dumped causing the cat to go bad.
- ferris48
- Thank you received: 47
8 years 5 months ago #20802
by ferris48
Replied by ferris48 on topic 03 Lancer DTC Codes
Quick test to see if it's a coil issue: swap the coils and see if the cylinder 2 misfire goes away.
www.scannerdanner.com/scannerdanner-prem...se-study-part-3.html
Start watching at 09:11 and Paul will swap the coils in the video and you can see the tools he's using for the job.
- Darkendrain
8 years 5 months ago #20830
by Darkendrain
Replied by Darkendrain on topic 03 Lancer DTC Codes
Thank you for the information and recommendation. Would it be a good idea to get a compression test kit and check cylinder 2 before buying?
8 years 5 months ago #20913
Replied by Tyler on topic 03 Lancer DTC Codes
I think that'd depend on how much use you think you'd get out of it? You could always rent one from a local parts store if you don't want to spend the money on a good test set.
If I was the perspective buyer here, I'd probably settle for an audible relative compression test. Quick, simple, and doesn't require any disassembly. If I didn't hear an issue, I'd roll with it.
