Lean running 1az fse gdi engine
  • jahvii.williams
  • jahvii.williams's Avatar Topic Author
1 year 8 months ago #82181 by jahvii.williams
Lean running 1az fse gdi engine was created by jahvii.williams
[ ] Parts replacedGenuine maf sensor and vvt solenoid[ ] Fixed small vacuum leaks. Diagnosed using smoke leak detector.[ ] Replaced bank 1 sensor 2 o2 sensor genuine. Still have original bank 1 sensor 1 Air/ Fuel sensor on engine.[ ] Tested fuel pressure with gauge intank is between 50-60 psi and high pressure fuel pump is within ranges 1,168 psi and up.( Toyota Recommended value)[ ] Replaced 4 fuel injectors Genuine (Refurbished)[ ] Having a slight cold start rattle ( Confirmed coming from vvt actuator) Vehicle still has alot of power, no drivability issues. Only high positive fuel trims.
I THINK I MIGHT BE STILL DEALIING WITH A VACUUM LEAK SOMEWHERE.
YOUTUBE VIDEO LINKS BELOW
youtube.com/shorts/-NIbsQlN95o?si=lzyLRvVT-qVWS0tx
youtube.com/shorts/q0-4-BuR9A4?si=GmHbD-GhysqN6LKG
